Luk, Home stereo speaker wire size. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Speaker Impedance
8 Ohm Load
6 Ohm Load
4 Ohm Load
Wire Gauge
Distance (ft)
Distance (ft)
Distance (ft)
18 AWG
10
8
5
16 AWG
14 AWG
12 AWG
60
45
30
10 AWG
Above chart by Audioholis
Speaker wire guide
Speaker Cable Gauge AWG Guidelines Recommendations
5 Myths About Speaker Wire
SOURCE: Yamaha R-V905 constantly turns itself off
Two things I think are happening. It is overheating and it has suffered some sort of damage to a component inside. Try to make sure there is ventilation on all sides. Can you remember a time where you did not have adequate ventilation for this device? If so maybe that is what caused the part inside to fail.
Hope this helps
Thanks for reading!
SOURCE: My yamaha receiver shuts down when I turn it up.
If you have bare wire going into the receiver's output terminals, make sure a strand or two of wire is not touching the other terminal. That can short out the outputs, especially when you turn up the volume, which increases the voltage present at those terminals. That would cause the receiver to shut down as a saftey precaution.
SOURCE: Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
SOURCE: HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
SOURCE: Yamaha RX-V365 Receiver, Yamaha NS-AP2600S(BL) Speakers
I have the same issue. I took the speaker apart and tested with a meter and both the mid and tweater were wide open, in short blow out. Not sure what caused this but the speaker needs to be replaced.
Any real speaker wire ..dont cheap out
