Question about Sylvania DVR90VE DVD Recorder/VCR
Trying to unlock parental control on my sylvania VCR/DVD player. Accidentally locked all six locations.
Can't view anything or any movie I insert into player.
  • Sylvania Master
  • 5,686 Answers
It should explain it in the user manual, if you don't have one try the makers website they often have free PDF's of them.
Posted on Jan 29, 2013
SOURCE:
  • 130 Answers
SOURCE: Sylvania DVC850C DVD Player
Sometimes the mechanism that spins the disk does not go up or down all the way then when it tries to eject its not all the way in idle. Could be from heat With it unplugged try and tip it upside down, maybe that will let the mechanism go back to its resting position so you can get it out. Reguardless it sounds like there is a problem that needs looked at inside the unit.
Posted on Apr 10, 2006
sandrew
  • 2961 Answers
SOURCE: HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Posted on Feb 08, 2007
SOURCE: Sylvania DVR90VE DVD Recorder / VCR - formatting DVD-RW
This unit only supports 2X -RW discs or 4X -R discs.
Posted on Oct 28, 2007
DOCTOR VIDEO
  • 131 Answers
SOURCE: Sylvania DV220SL8 DVD Player/VCR Combo
You could try cleanining it first that would be a simple solution
Go buy a video head tape or due it yourself radio shack has video head cleaner. Remove cover unplug clead small silver audio head on right side. good luck
doctor video
Posted on May 18, 2008
  • 135 Answers
SOURCE: Unlock region codes
Go to www.videohelp.com enter your machine's model number, hit search, then scroll down and look to your right- If there is a region free hack for it they will have it...If it is a new model, you might want to check back with them in a month.
Posted on Jun 30, 2008
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
Apr 20, 2014 | Zenith XBR716 DVD Recorder / VCR Combo
Can't view recorded DVD
if the movie you recorded ? was copy protected. then your dvd prob did not record
Nov 22, 2012 | Magnavox ZV427MG9 DVD Recorder/ VCR
What is a sd card fof
If you store movies on a SD memory card you can insert the SD memory card into this player to view the movie. You may have taken a video of your children on a video camera which stored the video on the SD memory card.
For information for viewing movies/videos on a SD memory card check out page 18 on the User manual.
If you do not have a manual then you can download the user manual from this WEB site
http://www.manualowl.com/m/Magnavox/NB500MGX/Manual/254277
Oct 24, 2012 | Magnavox NB500MGX BluRay Player
Unlock pin on hannspree 22
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Sep 17, 2012 | RCA 24V511T 24" TV
How to unlock childs security?
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
Instructions
Jun 28, 2012 | Sansui DTV3200 32" TV
How do i get a vcr to work without a remote
Answer #1: You can get up out of your chair walk over to your TV & VCR player and
Turn it ON then Insert a VCR Tape then Turn on the TV,Hit the Play Button
on your VCR Then go back and set in your Chair AND ENJOY the Movie.
When the Movie is Finished You do the same thing all over again Except in Reverse. I do this every time I want to watch a Movie. Answer #2:You
can go to the Electronics Store and Purchase A VCR Or DVD Player that Does Have a Remote or Just Buy a Universal Remote for about $10.00 it has all the codes for all TV's, VCR & DVD Players in the Package. I sure hope that one of these Answers is of some Help. Good Luck!
Apr 10, 2012 | Sylvania 6419TA 19" TV
How do i unlock it
Mar 10, 2012 | RCA 24V511T 24" TV
How do i play movies on my i pod
We picked up an iPod Photo the other day, and most observers have asked us "Can that thing play movies?" The short answer is no, only music and photos-but the longer answer is "sorta, but not really anything worth calling a movie". In this week's how-to we'll show you how to "play" a movie on an iPod Photo by exporting frames of a movie, importing them to the iPod and playing them manually by click-wheeling through thousands of images, or even viewing 3d views of objects. Pointless? Yes. Will a lot of people try this and put movie trailers and **** on their iPod Photo.
Feb 15, 2012 | Audio Players & Recorders
How do I view movies in 3D on the Mitsubishi WD-Y65?
WD-Y65 is NOT a 3D ready TV. You either have to change the TV to see the movie in 3D, or just watch it in 2D in you current TV.
I have the same TV as yours. Current I connect a desktop PC to the TV via DVI port, and I watch Avatar using colorcode 3D(Amber/Blue) with Stereoscopic Player from www.3dtv.at It might be a way for you to enjoy 3D without change the whole thing, but it's an entire different topic.
Jan 08, 2012 | Mitsubishi WD-Y65 65" HDTV
Sylvania DVR90VE DVD Recorder/VCR Logo
118 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
