Minolta magicolor 2300W Laser Printer Logo
Diebesbeute Posted on Jan 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica Minolta Magicolor 2300W not transferring toner to paper.
Hi, After being stored for several years, I went to use my old laser printer and initially printed a test page from Windows where I could only faintly see the colors in the windows sign and see no black at all. After trying to print, It gives me a paper jam at the back panel of the printer as the paper does not fully come out of the printer, the last centimeter or so is still in the rollers. I can see the image of what I am trying to print on the silvery roller in the back and the rubber roller that presses against this. So I believe that the toner is not transferring to the paper correctly so the fuser is not able to do its job of melting this to the page. Any ideas? Or is it time for this old horse to be put out to pasture? Thanks!
Adorjani Laszlo
Level 3:
  • Minolta Master 1,316 Answers
  • Posted on Jan 30, 2013
Adorjani Laszlo
Minolta Master
Level 3:
Answers
1316
Questions
Helped
456920
Points
2563
Clean the paper feed rollers,the fusing unit rollers and print the blank page(min.10-15) for clean the upper fuser hot roller.Agiting the toner.
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on Jun 19, 2008
SOURCE: paper jam
open doors and find these solenoids, clean them and make sure they are moving fine, its not so hard. just step by step move with paper and find out where the solenoids are. solenoids aren't expensive so if its a solenoid problem you should fix it
Anonymous
  • 2985 Answers
  • Posted on May 26, 2007
SOURCE: Minolta 2300DL Printer - black streaks
you will have to check the Minolta web tech support team for this one.
Inky
Inky Fingers
  • 705 Answers
  • Posted on Jun 11, 2007
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
Anonymous
  • 29 Answers
SOURCE: Minolta 2350DL laser printer paper jam that will not clear
You have to take off the roller . :)
gregg_morris
  • 8 Answers
  • Posted on Mar 13, 2011
SOURCE: to change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Konica/Minolta 2350EN - first page printed is shifted lower on the page, about half an inch. Subsequent pages are better until after about 5 pages, everything appears normal. When printer cools down,
Sound like maybe the printers is printing incorrect paper size check settings in user/admin mode check printer properties metric vs inch.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Where is the waste toner bottle on magicolor 4750 printer
the waste toner bottle should be below the toners themselves as seen here: 2_20_2013_9_33_39_pm.jpg
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Driver
Here is the link to download your driver.
Thanks
1helpful
2answers
To change opc drum in konica minolta
Switch Printer Off
Toner will transfer to the transfer be
As I understand it from servicing laser printers, the toner is actually drawn statically to the paper from the drum by a charge on the belt. Toner is not supposed to be distributed to the belt. The fuser fuses the toner to the paper after the transfer. Can you access the fuser rollers to see if there is any sign of wear or damage they may be keeping the paper from entering it properly? The toner on the belt is probably excess from the paper not being pulled through and having the toner fused properly.
Won't transfer from the transfer belt to the paper
Where is the Transfer roller. was that replaced also when replacing the transfer belt ITS a SPONGE LOOKING ROLLER same lenght as the width of the belt
2answers
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
