Question about Measuring Tools & Sensors
What is the difference between rebar locators and cover meters?
    Sergeant:
  • 190 Answers
Profometer and Profoscope rebar locators and concrete cover meters. ... Locating rebars is a necessity when drilling, cutting coring as well as a preliminary operation required for most other non-destructive investigations. Best Metal Detector In 2017 Tested Reviewed by Detecting Expert
Posted on Jul 02, 2018
    New Friend:
  • 152 Answers
Rebar detectors are less sophisticated, in that they only detect metal below the surface. cover meters can tell how much concrete is covering the rebar
Posted on Jan 28, 2013
SOURCE:
If steel rebar sheets are 3.6m by 2m how many sheets would i need to cover 10117 square meters
3.6 X 2 =7.2 sq meters
10117 sq meters divided by 7.2 = 1405.13 or 1406 sheets as you cannot get a part of a sheet
grade 3 maths really
Feb 19, 2017 | Office Equipment & Supplies
Where is the fan control located
I know the caravans fan relay is located on the front rebar behind the bumper cover while looking at the front of the car it would be on the right hand side..... they may have put the liberty there also.
here is where the caravan is
https://www.youtube.com/watch?v=pxfDwsH7jk8
Jun 22, 2014 | 2005 Jeep Liberty Limited
How do I read my rebar locator screen?
Most rebar locators have very easy to understand screens. There should be an indicator for when you are moving towards or away from the metal there will be a plus or minus sign. There should also be a depth indicator telling you how deep down the metal is. That is the basics, you when you find the points where the plus turns to minus in two directions go up and down making sure the depth is consistent this will tell you if its rebar or just scrap metal.
Jan 16, 2014 | Measuring Tools & Sensors
Through how much concrete can a Zircon MetalliScanner MT6 find rebar?
I believe that detector has a limit of 6 inches of contrete.
What is a rebar locator used for?
A rebar locator is used to find and locate rebar reinforcements in a wall, usually made of concrete.
Can I use a portable bandsaw to cut rebar or do I need something stronger?
you can use a portable bandsaw to cut rebar, I find it to be the best solution when I can't take the rebar somewhere to cut it. But be careful if the metal is heavy it could fall and dent/damage the floor if you're working indoors of cause injury should it land on you.
Nov 14, 2013 | Cutter Tools
What protective gear should I wear when cutting rebar?
Wear protective gloves because rebar tends to get really hot when you're cutting it, you should also be wearing clothing that you don't mind ruining and isn't too flamable because sparks will come flying off the rebar when you cut it. Make sure to wear eye and face protection as well as sturdy shoes. This is not a job for the flip-flops!
What is rebar?
rebar are steel rods that are used to reinforce concrete, usually found in buildings.
How do rebar locators work?
they use pulse-induction method. coils in the probe are charged by electric pulses, which generate a magnetic field, and when rebar enters the magnetic field the probe can measure how strong or weak the magnetic pull
Jan 28, 2013 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
925 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
