SOURCE: MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
SOURCE: need to connecte wires to power sw, HHD Led etc. for pm8m mother board
pls see this with diagram
SOURCE: CONNECTION MOTHER BOARD MSI 7043
connection to the motherboard as per your query is not critical. you can do trial and error method, since an LED connected in reverse will not damage it, but just show no glow. so just reverse again, if it glows then its okay if still no glow then the LED is dead. Anyway, if you need the manual you can download from this link: http://global.msi.com.tw/index.php?func=downloadfile&dno=3825&type=manual
SOURCE: MSI mother borad came home with wires un hook
In your original subject line you list your motherboard as "MSI K8N Neo4-F Motherboard"
In your original message under that title you list your motherboard as
"MSI k8t Neo 2"
Go to this link
http://global.msi.com.tw/index.php?func=prodarchive&maincat_no=1
Double check and get your CORRECT motherboard number off the board itself.
Find it in the list and click on it. You will see options for drivers and manuals.
The manuals will tell you how to hook up your board.
These downloads are free.
if by chance this link doesnt work by the time you get this.
Google MSI + motherboards and you will see the maker of your motherboard.
Go there, select mainboards from the list of products and you will get the list I have recommended. Again, look for the correct motherboard number and click on it to get drivers and manuals.
Thank you and good luck. *s*
SOURCE: Hi, need wiring/connection help if
Here is the whole manual
http://global.msi.com.tw/index.php?func=downloadfile&dno=3854&type=manual
