Turns on recognizes kettle and button works to select boil but then clicks and nothing happens although red light stays on saying kettle is trying to boil
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
SOURCE: light switch on Breville SK500-XL Kettle
e mail [email protected]
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
SOURCE: filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
SOURCE: Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
SOURCE: The "boil/black tea" button quit
there is a 1 year warranty on this unit. In order to have it repaired you would need to contact breville at 1-866-Breville in order to have your unit repaired most likely you have an error witht the touch control and would need to send the unit in to them for the repairs to be made here is also there link that states there warranty information as well http://brevilleusasupport.com/product/bke820xl?lm_search=Breville+BKE820XL+Electric+Kettle if you have any further questions message me back Thanks Rick
