How to bring sewing foot holder to embroidery position
Hi, I hope this helps. If it doesn't post again.
"Check:
Place the sewing foot under the sewing foot
holder so that the pins of the foot snap into
the sewing foot holder when the presser foot
lifter is lowered.
Please check that the sewing foot is properly
engaged by raising the presser foot lifter."
Question: Are you using top feed? If so:
"For all sewing jobs with the top feed, only use sewing feet with Cutout at the back (OA, 1A, 3, 4)."
Embroidery foot Part No.: 98-694-840-00 will not work with top feed.
Also, except for eyelets, the darning foot can be used for embroidery.
I'm not sure what you're trying to do :) darn or embroider :); I'm not sure what mode you're working in either; embroidery mode?
Darning with straight stitch
Program 00
Fit darning foot No. 6.
Set the needle at its highest position by turning
the handwheel, and push the pin of the darning
foot fully into the hole of the sewing foot holder
slightly pressing the darning foot between thumb
and forefinger. When doing this, the guide fork
should place itself around the presser bar and the
wire must be behind the fixing screw.
Darning position:
Lower the presser foot lifter pressing it lightly to
the rear until it snaps into the darning position.
Important Only in this position you have the
optimum thread tension for darning.
• Place the darning work in the darning hoop.
• Lower the feed dog.
• Pull up the bobbin thread and hold the threads
when you start sewing.
• Now guide the fabric back and forth evenly;
the length of the darn will be set by the size of
the hole. As you are determining the stitch
length yourself while sewing with the feed dog
lowered, you should sew at an even speed.
When you have reached the width of the dam
aged area, darn over the damaged area again
from right to left.
This guarantees a durable darn.
TIP: The faster you sew, the easier and more even
the darning will be. It you are moving the workpiece
too slowly, small knots will appear on the
wrong side of the fabric."
Whether working with terry-cloth or woven fabric,
with the help of the darning foot and the pro
gram 02 you can embroider initials of your own
design
Drop the feed dog and insert the darning foot.
Put the machine into the darning position.
Spread the fabric in an embroidery hoop and
embroider in accordance with program 02.
Lower feed dog
If the feed dog is not lowered for embroidering, the
machine does not embroider when the foot pedal
is pressed and the message appea rs:
Lower feed dog
ok?
The feed dog must be lowered in embroidery
mode.
Model Husqvarna Rose 600 Computerized emroidery machine
Same problem as emnsam. Machine has been serviced 3x and continues to be problematic. Any help would be appreciated as I'm loosing patience.
I am having the same problem, put the presser foot down to sew and it beeps and flashes the presser foot symbol will not sew. Help! I am taking my Rose to be repaired.....hopefully it doesn't cost an arm and a leg.
same as emnsam--I have cleaned the maching, rethreaded, checked bobbin , checked bobbin rewind, unplugged and tried again. the needle will go down and then the pressure foot flashed and then nothing.
we're having the same problem....very happy to find these posts so that
we know what we are dealing with. If it's just a pressure spring,
perhaps we can replace it ourselves.Maybe we can put a jumper wire
across the terminals on that sensor (on top of the needle bar) that is
getting the bad signal from the weak spring, and make the connection
that would be made by a stronger spring.
I've got the same problem and would be thankful if there's any solution without giving the machine to the shop.... problem of not enough money.
Sorry for my bad english but I'm from Germany
Britta
having the same problem with the presser foot. signal comes on everytime i get ready to sow. It says the presser foot is in the up position.
I have the same problem. Fabric is in place, foot is down, but needle only goes in once and foot symbol blinks and machine will not go any further. Frustrating!! I need to finish a project and repair shop is closed for the holidays!
Presser foot issue..if I press hard and jiggle it will work when I life it and start again, back to the same problem///Husky rose
I have the same problem as emnsam. My machine is a Husqvarna Rose Type 600, 10902763. It will not sew. The pressure foot blinks, you get 3 beeps and the needle only moves one half of a stroke. If you wiggle, jiggle, and manuever the pressure foot lever around you can get it to sew eventially. Is there a repair I can do without taking it in for service
I have a Husqvarna Rose 600, 10902763 which will not sew. The pressure foot blinks and I get 3 beeps. If I wiggle the presssure foot lever, and jiggle it for a while, I can finally get it to sew, but as soon as I lift the foot up I go back to the same problem. Is there a way I can make a repair to correct this without taking it in for service?
Pressor foot doesn't go down all the way
when pressing sewing foot needle lever does not go up and down why?
