You can't convert litres to pounds, at least not directly. The litre is a volume measurement, not one of weight (mass, actually). A litre of one material may not have the same mass as a litre of a different material, so a simple conversion factor doesn't exist.
If you know the specific gravity of the material you want to measure, you can convert the volume to a weight. Water is defined to have a specific gravity of 1.0, and 1L of water = 1 kg. One kilogram is approximately 2.2 pounds (you can look up the conversion factor if you need more accuracy). So if you are dealing with water, 8 L is around 17.6 pounds.
If you aren't measuring water, find the specific gravity of your material, and multiply by that value. A liquid with a specific gravity of 0.75, for example, would have mass of 0.75 kg per litre, so 8 L of that material would weight 0.75 times (or 75%) of 17.6 pounds. But without that specific gravity figure, you can't convert litres to pounds.
1) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher. (leaves 7 litres in Pitcher 16)
2) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher. (leaves 2 litres in Pitcher 9)
3) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
4) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
5) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 5 litres in Pitcher 16)
6) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 4 litres in Pitcher 9)
7) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
8) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
9) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 3 litres in Pitcher 16)
10) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 6 litres in Pitcher 9)
11) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (leaves 0 litres in Pitcher 7)
12) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 0 litres in Pitcher 9)
13) Pour the water from the 16 litre Pitcher into the 9 litre Pitcher (leaves 1 litre in Pitcher 16)
14) Pour the water from the 9 litre Pitcher into the 7 litre Pitcher (leaves 8 litres in Pitcher 9)
15) Pour the water from the 7 litre Pitcher into the 16 litre Pitcher (Pitcher 16 also has 8 litres)
YOU NOW HAVE 8 LITRES IN THE 16 & 9 LITRE PITCHERS.IN 15 MOVES.
Puzzle 5 -- Answer is Ten Times 10
Puzzle 18 -- Move Top far Right Match to Left of the Dust-- Move Middle Match slightly Left to make the Handle.
Puzzle 23-- Empty 8 (Litre Pitcher) into 5 (L.P) Empty 5 (L.P) into
3(L.P) then empty 3 (LP) into 8 (L.P) then 5 (L.P) into
3(L.P) then 8(L.P) into 5 then 5 (L.P) into 3.(Litre P.)
Pour contents from the 3 (L.Pitcher) into 8(L.P) You
will have 4 Litres in two of the Pitchers.
Puzzle 27 -- Bickering Brothers -- Sit them clockwise from the top
as follows -- 1-- 3-- 6 -- 4 -- 2-- 5 -- .
Puzzle 28-- Find the Dot. Bottom Point on the Right.
Puzzle 36-- Only 1 as the mouse you bought was a MALE
Puzzle 37-- Brother & Sister-- They were Twins Age--- 6 (SIX)
Puzzles 38 - 41 -112-- are all quite easy, just play around you will get the Answers.
can realy help withoutsee puzzle but here are a few answers i can remember no.62 is 8 no. 85.is 60no.109 go from start to bottom right up to top right then across to left exit .hope this helps
i don't know what the answer is to #78
i don't know how you do the puzzle
