Question about Kirby Ultimate G Bagged Upright Vacuum
How do I shampoo my upholstery
Iknow how to clean carpet but cant figure out how to hook up upholstery attachments.
  • Kirby Expert
  • 324 Answers
Instructions are HERE. Try shampooing on a part of a furniture that is not visible much... sometimes this may not work well.
Posted on Feb 28, 2009
SOURCE:
I cant figure out how to **** up water with my kirby dimond
Vacuuming a wet carpet with your Kirby or any other vacuum not designed for wet pickup could do serious damage to your machine and there is a real danger of electrical shock to the operator.
Your Kirby Diamond and every other Kirby for that matter is NOT designed to pick up water!! Even with the shampoo system attached it will NOT pick up water or the shampoo foam. Your Kirby spreads the shampoo foam around on the carpet to clean it. You then only vacuum a shampooed carpet after it has completely dried.
May 20, 2010 | Kirby Ultimate G Bagged Upright Vacuum
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Dont know how to hook up the carpet cleaning part of the vacuum
You have to have the Aquamate II shampoo attachment in order to clean/shampoo your carpet. Go to the Rainbow website and you can purchase it if you don't already have one - if you do have one, this site also has simple directions on how to set up the Aquamate to shampoo your carpet.
May 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Does my kirby come apart to where i can shampoo furniture . can i use kirby on berber carpet. i have the G series
YES there is Kirby upholstery shampoo attachment that comes in a standard set of attachments - HERE is the instructions. Try it on inconspicuous area first just to make sure that this is going to work on your upholstery. But I would just buy a can of upholstery foam. If you can not find it in a store - try automotive store - they definitely have it. Spray can is just much more simple. Still try it somewhere where you would not be afraid to damage the color first.
Using shampoo attachment on berber carpets is not as effective as on the regular carpet. Brush cant get to brush the fiber from all sides. You may have to shampoo berber rugs from several directions to get the better result.
Mar 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I cant find my manuel for my steam cleaner and I want to use the uphostery cleaner dont know how to hook it up can you help me?
In front at the bottom thiers is a peice mine is square pull it up and out, now take the top of the tank lid off. now slide your upholstery attachment in that place where you pulled out the sqare. the open end facing up, now put the tank lid back on every thing should work .your welcome ttsgma01
Sep 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning uphoustry
Furniture cleaning isn't a science: try out a few techniques before choosing the one that is right for your belongings. This step-by-step guide explains how to clean a sofa:
  1. Before using any upholstery cleaning products, vacuum the sofa or chair first to remove as much surface dirt and dust as possible. Be sure to use the correct attachments to avoid damage to the material - a soft brush attachment is ideal.
  1. Spot Clean. Using baby wipes or vinegar poured onto a strong microfiber cloth, apply to any obvious stains, wiping gently as you go. Remember to test the upholstery cleaning products on an inconspicuous area first.
  1. Overall Clean. Using soapy water and a microfibre cloth, gently wipe your sofa with the solution, allowing it to soak into the fabric and tackle the dirt beneath the surface. You only want to use a very small amount of water - don't saturate the material.
  1. Dry. Some people use a hairdryer to quickly dry a sofa, but allowing it to dry naturally is always the better option, if you have the time. To speed things up, open windows and allow the breeze to help with the drying process.
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Apr 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
How do i put together my kirby carpet shampoo system?
Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing. Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up. a4bbc62.jpg Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray. e14fe2e.jpg While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attaching Bar.
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Then lower the Headlight Hood
Apr 18, 2008 | Vacuums
Cleaning uphoustry
I CANT FIRGUE OUT HOW TO PUT IT TOGETHER
Mar 05, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Kirby Ultimate G Bagged Upright Vacuum Logo
740 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
