F11 - No pump connection.The drain pump is either blocked or drain pump is loose or drain pump hoses are loose .Or the drain pump connections are faulty.The error f-11 is related to drain pump and its connections,.-----------You can get required parts from www.repairclinic.com Thanks. Keep updated for any more query. You can rate this solution
and show your appreciation.
If you have a Kenmore or Dacor, Thermador, Amana Caloric, Westinghouse, Admirals, or if you have some retagged oven from this brands, F2 is temperature runaway, usually a bad temperature probe.
On Admirals you may need to test the relay board.
Try disconnecting power (trip circuit breaker or disconnect power cord).
If the error is still there, test if the probe has continuity, then eventually replace it.
On Whirlpool ovens F2 is a faulty keypad assembly.
To get a technician to do the repair call the support number listed on the manual.
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
