i have a poulan 2150 chainsaw that leaks bar oil when it is stored. How do I solve this issue?i have a poulan 2150 chainsaw that leaks bar oil when it is stored. How do I solve this issue?
try and run it with the muffler off the build up with carbon and restricted the exhaust flow as for the oil leak mine the screws became loose behind the clutch for the oil pump
I would say that it's time for a new chain. After using for varying periods of time the chain will stretch too far to be used anymore. This is caused by heating during usage. Some things that will cotribute to chain wear out are insufficient bar oil, dull chain or just every day wear. I think if you get anew chain you'll be fine. When I'm tensioning my chains I run the saw at high rpm for a couple of mins. Shut off and grasp chain by mid-point of bar and lift up. I try to get enough space to slip a nickle between bar and bottom of chain. You should check tension often, as over tightening also adds to wear on chain and motor. Hope this helps you. Thanks
The easy fix is to drain the oil tank when not in use. Many saws will leak some oil initially, but should not continue to do so. If it is making a large puddle, oil is getting past the oil pump which may be worn from long use. Make sure the tank vent is not plugged as heat from the engine can increase pressure in the tank thus forcing oil out. Hope this helps!
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
If the oil level in the chain oil tank goes down normally then you may be running the chain too tight. Also make sure the oil ports in the bar are clear so the oil can get to the chain. hope this helps you
The chainsaw squirts oil into the oil hole in the bar. The chain picks up the oil and carries it all the way around the bar lubing it and the chain. When you quit running the saw there is still a lot of oil on the chain and all away around the chain guide in the bar. Once you quit running it and it sets a while all the oil will follow gravity and run to the bottom of the bar and drip out into the case. It's just another one of life's little nuisances. Have a nice day! Obwhon
Sounds like you're not getting enough oil to the chain. Basically you've got an oil pump, pickup and filter involved in getting oil from the resovior to the chain/bar. If you cleaned the obvious area and the chain is not coated with oil, you may have a clog further up (inside) the oil delivery mechanisms. Also, drain the oil from the tank, and see if you can "blow" air through there. With the saw running & pointed down, you should be able to see oil on the ground being slung off the chain, if not, you are not getting enough oil to the chain.
Sorry to tell you this but you need a new OIL PUMP but it's not a difficult thing to replace. On the main shaft of the crank shaft under the centrifugal clutch is a spiral wound wire that matches a plastic part that is the oil pump. You can get the part from Poulan parts and it will take about 15 minutes to fix the first time eight minutes the second time. Glad to be of assistance.
Is there a thin metal plate that sits behind the bar, and have you had the bar off?
