Question about HP OfficeJet 4215 All-In-One InkJet Printer
Fax wont send or receive. - HP OfficeJet 4215 All-In-One InkJet Printer
    Genius:
  • 2,120 Answers
Check the phone line with a regular phone.
Posted on Jan 31, 2009
SOURCE:
I have dial tone but wont receive fax, can send out fax
Be sure thephone line is in the "line" plug, not the "ext" plug on the back of the machine.
Aug 22, 2014 | Brother Office Equipment & Supplies
Cant send or recieve fax
Might be silly question but is it setup to auto transmit and receive? And have you tried to operate it manually? + take out the inline filter fax machines operate on volume'db' to soft and it can't hear, to loud and it can distort sound.
Dec 28, 2013 | HP Office Equipment & Supplies
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
My fax machine wont send or receive faxes any suggestions?
If it is properly connected to the jack in the machine and the wall, and it won't send OR receive...then it's NOT a simple problem, because nothing else need be done for the machine to at least "send" a fax.
Dec 15, 2009 | Ricoh FAX1180L Laser Fax
Can send faxes, but no fax tome coming on when the number is called
that's right,you would be able to send fax,but wont be able to hear the fax tone,your fax ring shoud be 2 rings higher than answering machine,or else,do 1 thing when you hear the ring,just pick up the receiver u wud be able to hear the fax tone,do not disconnect the call,just keep the receiver aside without disconnecting,and then press start fax...you will be able to receive fax...........
Aug 25, 2009 | HP Hewlett Packard Officejet Pro L7680...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
I can receive faxes but cannot send them
Check your fax speed settings, also, make sure you get a good clear dial tone on the line. Sometimes it wont send if it detects line noise.
May 01, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Lexmark 7100 series will receive faxes but wont send them
I have a problem sending/receiving faxes. I have been trying to send a fax but it will not go through.
Mar 19, 2009 | Lexmark X6170 All-In-One InkJet Printer
X5495 wont receive a fax - can send one though..
that means that the fax machine on the other end, can't read your handshake from lexmark. Happens.
www.lexmark.com has the drivers you'll need by model and operating system
http://tinyurl.com/6qcpgy
Aug 07, 2008 | Lexmark X5470 All-In-One InkJet Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
