John Pittari Posted on Jul 29, 2007
Display Problem for Philips FR951PBK01 receiver
So, my brother moved out recently and passed on this awesome reciever to me, but there's one problem with it. When I turn the receiver on the display does not work. At all. Just curious if anyone has seen this problem before or knows how to fix it. Any and all help would be appreciated. Thanks.
  • Anonymous Dec 24, 2008
    same thing. working on it now. if i get it fixed i will repost. did you have any luck?
Bennie
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 15, 2013
Bennie
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1546
Points
I repair one shortley, remove the bottom plate and re-solder the visual bad connections and special the cable connection from the display that is half under the metal bottom. Succes, Ben
A
Anonymous
Mine does same thing and the thing he says works
if it dont work by turning it on and turning the solector nob wait about 10 min after moving the nob it will come back
A
Anonymous
Hey i own it too mine same thing but when i turn mine on i use the selector and the display comes back on so push power then spin the selector knoby thing it should work
No image, only sound when connecting marantz sr 7005 hdmi out to hdmi in on tv philips 47pfl9632d
Whatever video components you have, they should be, depending on inputs on TV, should be run to TV first. Recievers do have pass through ports but, are not the best way to achieve picture and sound. HDMI cables are great but you r reciever may not be able to transfer the video. What I suggest is taht you run your componenets, cable/sat box, DVD, etc. via HDMI, componenet, etc., to TV input, then, run audio out from TV, via(best) digital optical. You can use TV's menu to choose what you watch while, you only have the one input to reciever. Scan your recievers menu to make sure you have selected the proper mode(TV, Aux, Vid2, etc.).. If you run your video unit to TV with component cables, you will have to get your sound through separate cable(s). Component cables have graet video, but do not carry the sound.
2answers
Stuck on manual recieve
Press the RECEIVE MODE button on the panel until the display reads FAX on the right side.
1helpful
I am trying to send a fax but when I select the fax start button it says on the display receive and the fax will not send brother 1020e
if you havent dialled the number first or don't have the page in fully (or it can't detect the page) it will go into recieve mode.
How do you change the clock display - I don't have
diplodocs is awesome http://safemanuals.com/user-guide-instructions-owner-manual/PHILIPS/DVP3100V-19-_D
Just hooked up Coax cable; now talking is barely audible
is the center speaker turned up in the reciever speaker settings? each speaker can be adjusted to a level that is higher or lower or all the same as the rest. also is the dolby digital turned on in the reciever settings? and changing the surround sound pre set sounds can also improve the type of audio you are listening to in 6.1 surround sound
Fax will not recieve but will send fax
what does the display reed. To receive fax automatically the display needs to reed
( fax mode or auto ) . If in the manual mode you need to pick up the receiver listen for the tones then press start.
make sure the phone cord from the wall jack is from the wall to the line connection MOT THE EXT. CONNECTION on the fax ( nothing in between the wall & fax )
hope this works
C.W.H.
One location doesn't recieve our faxes
The problem may be that the other company is running VoIP for their phone system. The Brother MFC 7420 is documented for not having VoIP compatibility as a marketed feature. In other words they were too cheap to include it. However, with that said there is a work around. I have include the link that may be helpful in resolving this issue.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002100/000023/faq002123_000.html?reg=us&Printable=true&c=us&lang=en
Best Regards,
Russ
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Reciever display changing by itself
Sounds like a bad microcontroller. First check on the function selector knob if there is one and make sure it is not stuck - move or rotate it back and forth. Also, if the remote is nearby, try removing the batteries from it.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
