DISH Network 311 DTV Receiver Logo
A
Anonymous Posted on Jan 27, 2013
Will a 7yr old dish receiver work today on dish satillite
Barry Barrett
Level 2:
Scholar:
New Friend:
  • Expert 73 Answers
  • Posted on Apr 28, 2015
Barry Barrett
Expert
Level 2:
Scholar:
New Friend:
Answers
73
Questions
Helped
40739
Points
254
With an antenna that is pointed correctly to satellites 110 and 119, the receiver will function, but will not have access to paid channels without authorization from DISH (which you can get by calling 1-800-333-3474). You may have to run a check switch test after connecting to antenna by accessing the menu, system set-up, installation, check switch.
Have a 17 yr old Magnavox and am unable to sellect aux channel so the dish will work
Hi there, my name is Kimberly and I form part of the Social Media Dept with DISH. It is my pleasure to help you today. The channel or Input in which the Tv needs to be on in order to receiver DISH signal depends on the type of cable being used to connect the DISH receiver to the TV. If you are currently using a Coax cable the TV needs to be on channel 3 or 4 in order to get a pic, if you are using RCA cables it will need to be an Input. To change inputs on the TV we advice you to use the original remote for the TV or the Input/Source button on the Tv itself. Feel free to contact me at: [email protected] for additional assistance.
Kimberly Escobar
Social Media Representative
DISH L.L.C
2helpful
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
Installed a new 625 today replacing any old 510 receiver. On the new 625 I cannot get TV2 to record--can only get TV1 to record. Have called Dish and was told to put in a DP separator. My husband did...
Hello! Dan Busa with Dish Network here. I know you've probably gotten this up and running by now but just for reference to anyone on this site. Any cabling or connectors used to carry signal to the receiver should be rated for 2,150 mhz if this is not the case you will typically get signal loss messages.
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
When i watch dish network my theater system wont work ,only if i watch dvd it works
I run my s video from the dish reciever to the tv/satillite s video input and the digital audio to the digital audio input on my reciever. The reciever is a sony V333ES and have no problems at all.
Dvd recorder to satillite
if your dish satellite has an extra A/V output or if your plasma tv has the outputs and the recorder has the same type input AUDIO/VIDEO jacks
Can not get signal no chanles
I would suggest to check lyngsat.com and satcalculator.freehostia.com for more info on where the satellites are and you will also find the elevation and azimuth for each satellite.
Hope this helps.
Satillite
More info needed...
What exactly do you want to do?
Which satellite, which band, what receivers, pay or FTA? etc etc
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
