Electrolux Band Aerus Lux Legacy Canister Cleaner Logo
A
Anonymous Posted on Jan 27, 2013
How to disassemble aerus lux legacy - Electrolux Band Aerus Lux Legacy Canister Cleaner
The light in my Lux Guardian Air purifier (Aerus) is blinking? What does this mean?
All you need is to replace the UV light. Call your local Aerus or Aerus Electrolux store get one delivered to you! Easy peasy.
Can't open vacuum bag compartment
The release button may be stuck or jammed, try pushing in on it and at the same time tapping the area around the button with a heavy wooden spoon, it may be enough to free it.
Have a lux legacy c 153c made by aerus comes on and runs fine for maybe 90 sec then shuts off and in about 90 sec will come back on .has great suc and runs great while runing
Is the motor overheating? Or is it more like there's a loose connection in the on/off switch? What happens if you reel in the cord a little? Could be there is a spot somewhere in the rings which is corroded or worn out and not making contact. Might also be a break somewhere in the winding inside the motor.
I have a similar situation in my Aerus C15C3. An Aerus brand bag ruptured inside my vacuum cleaner, but I didn't realize until the motor started making a horrible noise! To make matters worse, I hooked up my older Electrolux LE 1623 and at tried to suck as much debris out of the air intake at the bottom of the bag compartment, and then put the C15C3 back into service. I should have stopped then and there and started working on trying to get the motor and the fan out of the housing. But my machine was overheating and shutting off.
Sears Parts Direct has diagrams of the Electrolux LE 1623 on their website. The good thing about Aerus and the old Electrolux-USA is that they all have similarities in their design, but Aerus does like to tweak their design just enough to foil or at least complicate access to DIYers and general vacuum repair shops.
I hope you post what you find out!
How do you access the motor and guts of an Aeruslux or Electrolux Canister Vacuum Cleaner
Hi, I can help. Flip the canister on it's back. Remove all crews. Should pull apart from there. If not check around body to see if it's clipped. You may have to pry the sides apart. That will give you access. Be careful and pay attention to where everything is. Good luck.
Relay turns on but no water coming out to the pad. Water supply line working ok ]
Does the water valve cyilinoid valve get power and if so does it make a magnetic pull against a screwdriver. If not check to see if the windings are open with a ohm meter when the power is off. if has magnetic pull it may just be a clogged screen filter in the water inlet. I would check that first.
5helpful
How to disassemble Shark Mop s3601? I took all
You need to remove the shark and power button sticklers. There is two screws in each. Once you remove the screws you slide the grey cover and remove 3 more screws holding the chrome piece. Now you can spread the cover open. I just replaced a torn hose.
1helpful
Electrolux lux legacy
open up the unit, locate the cord reel, manually retract it to tighten the clock spring. should work again. lookout for broken plastics
Reset buttton location
The reset button for the power nozzle in on the top of the housing just to the right of the wand to tool connection. As for the tank; this is more a guess than an answer: There is a small hole at the bottom of the bag compartment. I wondered if that was a reset button, but the manufacturer recommends disconnecting the machine until it cools down and resets itself.
I know it is not much help. Electrolux Aerus does not want customers to repair their own equipment, and they will refuse to give out information.
Top Electrolux Air Purifiers Experts
eVacuumStore.com
David Kassin
David Kassin
Are you an Electrolux Air Purifier Expert? Answer questions, earn points and help others
