My p1i seems not woring properly...SMS SEND FAILED
what should i do?help
I have problem sending sms using sony K618i even after switch off many times
Take out your battery, sim and memory stick.. then turn it off for 5 minutes, then turn in on without inserting the memory stick. after that try sending sms again, if it delivered,then try it with memory stick. if u can send sms,then its ok..but if cant then your memory sticks got a problem.my suggestion is to format the memory stick..
Am using sony ericsson p1i in that sms is not moving i get msg as sms send failed wat to do? can any one solve the problem
I cannot send message to my sonny ericson p1i?
WHAT IS THE BEST SOLUTION...............
PLzzzzz anss????????
SOURCE: Lately, I have problem sending
This can be due to high traffic you sre not able to send message .
First check whether the setting is default in the properties of message . Then do master reset in your phone .
If you still have problem you need to contact service provider for correct setting .
i have the same problem that SE P1i does not send sms but is able to recv. Any solution?
