Floor is dull and appears to have a residue and even after I mop with diluted Pine Sol, there are streaks and some stickiness. I have tried rinsing with clean water and this doesn't seem to help. Any ideas? I've tried Once 'n Done by Armstrong and don't particularly care for this product because it doesn't seem to clean as well and costs well over $23.00 for a gallon. I have two dogs (daschund and rat terrier) and need a pet safe option that will clean, shine, disinfect and remove odor.
The old standby of glass cleaner should do the trick. Use a spray bottle, and spray a small 4x4 section at a time, let it sit for about 2min. , then wipe up with rags. Do NOT let it dry on the floor. You have a buildup of product on the floor. The pine cleaner has a small amount of oil in it and it builds up over time. For a good glass cleaner- I would suggest ZEP glass cleaner. For daily cleaning- I would suggest white vinegar 1 part vinegar to 3 parts HOT water. It will sanitize, and also remove salt stains from the floor left by winter boots and dog footprints.
SOURCE: I am noticing that my hardwood floor looks
This type of problem usually is not he fault of the Shark Steam Mop.
The problem is the old residue left on the floors by other cleaners.
Here is a tip that I wrote that will help you out with that problem...
Shark Steam Pocket Mop Cleaning Problems
heatman101
SOURCE: I use it on a
Hi, heatman101
Here is a tip
Shark
