HP iPAQ H6340 Pocket PC Logo
Posted on Jan 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installation of softwares
How can i install softwares and applications plus games in my hp ipaq h6340. when i run the any .exe file a message popups that its not a valid application. inspite that i always download the compatible softwares etc. for my ipaq. so kindly tell me what is the right method to install softwares, applications and games on my ipaq or what r the compatible softwares etc. for my ipaq? its version is 4.20.0 (build 14133 (c) 1996-2003 Microsoft corporation. hope u'll reply soon. thanx
vimal raj
Level 2:
Sniper:
  • Expert 64 Answers
  • Posted on Aug 08, 2009
vimal raj
Expert
Level 2:
Sniper:
Answers
64
Questions
Helped
21537
Points
142
I hope the ipaq is a windows based mobile, or what is also known as pocket PC. If am right, then it will not support .exe applications. Google your requirements specifying that your's is a Windows based mobile..
please revert back for clarifications..
I have a HP Ipaq H6340. I just got it from a
seem like all we get here are dead Ipaq.
why are you messing with this old device?
try a new battery, oops that costs money.
as does repairs on a device that has zero value.
why not mess with and old android phone, that has value.
ask here, be like only one playing Ipaq now.
https://h30434.www3.hp.com/
4helpful
Error 1316 occurred while down loading adobe 9.1 what is wrong. Wiil not let me down load any registry fix.
Hi upperroom50,
This message usually means a previous installation of a software is getting in the way of the new installation. It's kinda nutty that this would cause a problem, but we live in a nutty world. The fix is to download a free program from Microsoft that will totally and completely remove the old software. Then the new version can load unimpeded.
1. Download: Microsoft Windows Installer Cleanup Utility
2. Choose Save file option in the popup dialogue box
3. A File by name Msicuu.exe will be downloaded on your system
4. Run the Msicuu.exe application. This will install the program.
5. Run the Windows Installer CleanUp Utility file you just loaded (Start > All Programs > Windows Install Clean Up or C:\Program Files\Windows Installer Clean Up double click msicuu.exe
6. You will see window listing various applications.
7. Select the offending program, then click Remove. You'll see the warning box, select OK. The utility will remove all the parts of the program from your computer.
8. Restart your computer, then try loading the new version of the software.
Good Luck, and don't forget to leave a rating,
Thanks
Mark
2answers
Hpqthb08.exe and HPQDocViewer.exe error messages
****, since you have been having many issues, I guess that your windows is corrupted.
The best way to proced is to install a clean copy of Windows, install all of services packs and updates and then install the HP software and test the printer.
I know this is a lot of work, but it probably will solve this and many other problem that you are experiencing.
good luck!
O2 xda 2 mini application installation
There can be three types of applications that you download from freeware sites:
  1. '.cab' files, that can be directly installed from your PPC
  2. '.exe' files, which are direct to be run applications that need no installation, just have to be placed in any folder and a shortcut has to be placed in the start-menu.
  3. '.exe' setup files. These files have to be opened in your PC while having your PPC connected thru Active Sync. This will install the application to your PPC thru your PC. These should be the kind of applications that you might be talking about for which you get such an error message "Not a valid PPC application!"
I think this should have solved your queries regarding PPC applications.
If this really solves your problem, Please Rate...
Application not supporting
to install any application u need to attach the phone via cable with ur phone using active sync..then run the application on the pc it will get installed automatically on the pda.
Vanishing of sms folder.
If after a hard reset the PDA doesn't give you back the sms folder, it is most likely to asume that a ROM reinstall must be done. If you have a USB sync cable, check the HP site and download the ROM version for your Ipaq. Carefull with the rom upgrade, it's a simple process but must be done with care and by the instructions given there.
Hp Ipaq h6340
@Fanara
in the fall the simcard reader or the sim card connectors where damaged.
I would take the pda to a professional for analysis.
2answers
How to get a CD-ROM program to run?
You're probably going to have to set up an ActiveSync connection between your PC and your 2415, then run the program installer on your PC while you're connected to the iPaq.
PocketDVD problems
I'm a little confused. Most of the encoding programs I know like Pocket DVD Studio or Pocket DVD Wizard are programs you run on your PC (not the iPaq) in order to create a file which you eventually download to your card and play with Betaplayer.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
