If you do not have a router you have to reboot the modem first, Modems pair with one device at a time using its MAC address, using a router allows you to add remove computers to your internet access without rebooting the router for every device because the modem pairs to the router and the router shares its internet with your other devices.
SOURCE: speedstream 5200
here is the pdf download link for this modem http://www2.windstream.net/downloads/links/SpeedStream211.pdf should be of some use
SOURCE: speedstresm 5100 modem
the power light is graan, and ethernet light is green, and the DSL light is green. but the internet and acticity light is not on so i need to upgrade the modem that i hav't used in three years.
SOURCE: speedstream 5100
red light on DSL implies no ADSL communication to ISP. Check your phone line connection and make sure there are filters on all the other phone equipment in the home
SOURCE: HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM
hello
When you have modem plugged straight into computer, you can access it at
192.168.0.1, should ask for modem access code, (on bottom), then you
can click 'advanced' > ppp location and set it for 'on computer'.
There may also be a link for technician stats, it will give you info
about isp connection. You should / might be able to browse but ISP may
need original MAC address of machine (network adapter} you used when
1st signing up. Or if set to PPOE, it would look for name / PW in order
to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router,
access router, set PPOE > insert Log-in name / PW and save all
settings. Then try homepage, if no, have router "clone MAC address" of
the Network adapter you had the 5100 plugged into. Now it should work,
even if no <INTERNET> light. ETHERNET light should be constant.
Have router use DHCP to address machine independantly of what ISP
addresses router, which it will do when modem (having connection
confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into
ISP and then it assigns IP address with a timeout around 20 minutes. By
getting connection test results when modem is connected to computer, it
may seem to make sense, by understanding how ISP knows that modem
access code / MAC address, and lets the settings of modem determine if
router needs to sign in or not. If PPP is 'on modem', it will be
looking for the MAC address of computer, that is why you may need to
clone that address into router, so the router can appear as the machine
to the modem, than the router assigns net address to computer.
Regards
SOURCE: I am not able to ping the IP 192.168.0.1 of the
try ip 192.168.1.1
if still not work then reset your router.
Press RESET button of router for 10 seconds it is in back panel of router.
Then all settings are defaults.
then try
http://192.168.0.1
or
http://192.168.1.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration of router.
But before reset if in your router DHCP enabled connect your router to computer with ethernet cable Then go to start menu ->run
Type in run "cmd" then you see command prompt then type in prompt "ipconfig /all"
then you see ip configuration
Check your gateway ip it is your rputer ip then try to access with that gateway ip.
Let me know if you need more assistanse.
Thanks.
then press enter
