either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Normally, there is a master switch on the wall near the oven. This is in turn is usually fed from its own fuse/breaker on the consumer unit. I suspect this has bblown.
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
When you say that the oven turns on I assume that the oven indicator light is working. If this is so there will be only two likely causes for the oven not working. Oven element is faulty - check by performing continuity test; Wiring at oven element terminals burnt off - check visually. If you are handy carry out the above. If not, call a repairman.
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
