Mindscape PrintMaster Premier 7.0 Logo
Leslie Galuppi Posted on Feb 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which latest release of PrintMaster is compatible with PrintMaster 7.0 data?
I would like to upgrade PrintMaster 7.0 to newer version. Which newer version is compatible with 7.0, so that I can retrieve my current projects on the new program? Do I need to upgrade 7.0 before installing the latest PrintMaster?..do I then need to uninstall 7.0 to use the new program?
Joseph Wright
Level 3:
  • Mindscape Master 1,729 Answers
  • Posted on Feb 21, 2018
Joseph Wright
Mindscape Master
Level 3:
Answers
1729
Questions
Helped
455260
Points
5127
I hope this will answer your questions.. In general, I would think this would always be the case with upgraded software:
http://forums.encoreusa.com/tm.asp?m=38899
5 Related Answers
Anonymous
  • 268 Answers
  • Posted on Dec 20, 2009
SOURCE: WILL NOT LOAD ON MY
Of course yes.
Visit www.roxio.com and see what help you can get.
Cheers.
Anonymous
  • Posted on Apr 10, 2010
SOURCE: just purchased a new computer running Windows 7
to: Brettdixon16...............Why in heck would I buy a new Mac after just spending almost two grand on a new P.C.???? Thanks for nothing
Alun Cox
  • 2679 Answers
  • Posted on Aug 22, 2010
SOURCE: PrintmasterPlatinum 7 will not install
http://www.broderbund.com/p-137-printmaster-platinum-181.aspx
  • 6688 Answers
  • Posted on Aug 25, 2010
SOURCE: I have Printmaster 7.0 but it is not compatible
The upgrade path is to Printmaster Platinum 18.1 or Printmaster Platinum 2.0. I'm not sure which is better for you but both are $39.99 from http://www.printmaster.com/ .
The installers for Windows have changed over the years. Your alternatives would be to use a dual boot or virtual computer with XP installed. Win7 Pro and Ultimate allow you to run XP mode free after downloading two programs from Microsoft. All the other options require a licensed (paid) version of XP.
The compatibility mode is available but I'm not sure it will work in this case. You would need to right click on the installer and choose Properties. Then go to the Compatibility tab and chose an older version of Windows (Win98 may be a better choice than XP). Then right click on the installer again and chose Run as Administrator. Then you will need to do the same thing with the actual program.
I hope this helps.
walesarumi
Wale Sarumi KomputerSolution
  • 6993 Answers
  • Posted on Sep 15, 2011
SOURCE: Hi, I have used printmaster
the problem is that windows 7 is not compatible with Print-Master premier 7.0
The program cannot run on windows 7 because it wasn't programmed for it. This is why the error message comes up.
There is nothing you or anyone can do about this.
Sorry about this.
Regards.
Having compatability problems installing
Hi, PrintMaster is known for having versions that are not compatible with certain Windows Operating Systems, 18 is known to not work with Vista, yet works with 7 and XP quite well. The best solution would be either to upgrade to Windows 7 or get another version. Good luck!
I have Printmaster Platinum 17 on my computer. It has stopped coming up and will not reload. Is there a site where I can download it again? Maybe directly from the internet?
Lest's star by telling you neither me nor FIXYA had ever released any version of Printmaster Platinum 17. OK? So, if you want to contact authors of this sofware, ENCORE SOFTWARE
Encore Official Site Download Top Software Hoyle Card Games The Print Shop...
Now, HAVING SAID THIS, dd you use ever Printmaster Platinum 17 with Windows 7? I understand that it is for Windows XP.
I'm no sure what kind of a mess you made with it uninstalling or removing but well, try to reinstall your original SETUP version in Windows XP COMPATIBLITY MODE
Befor you instal it cricght click setuo, select Properties, click on tab Comatibility and select option Windows XP Comatibility mode
If won'r work, I find no way to help you,
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Have old printmaster platinum 8.0 tried to download on new comp windows 7 it says something about 16 bits
Printmaster platinum 8.0 is rather an old 16bits software and it is not compatible to your new version Win 7 OS.
You can check software compatibility @ Windows 7 Compatibility Center
Your option is to upgrade to version 18 which is Win 7 compatible.
Hope it helps.
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
1helpful
I am using an old (but good) Printmaster Platinum 11 and would like to update. A few years ago I got a detective Gold 18 which I cannot use. I have Windows XP Home and am being told that I must update my...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
I tried to put print master 16 gold on windows vista and i got a message that i need a print driver where can i get it andwill it work then
Printmaster Platinum 16 is not compatible with Vista or Windows 7.
Presently there are not "patches" to make it works.
Your options is to use the newer version eg. version 18.1
Hope it helps.
1helpful
2answers
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work...
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Top Mindscape Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mindscape Computer and Internet Expert? Answer questions, earn points and help others
