Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Sometimes the RF frequency from the outside transmitter loses contact with the clock's frequency ( it has happened to me only twice in 6 years ), and then the outside temp will not show. Simple solution to fix this is: Take down the outside transmitter and the internally mounted clock. Remove batteries from both. Wait about 10 mts. First install batteries in the transmitter, then after about 30 seconds, install batteries in the clock. In about 5 mts, you will find the clock showing the external temp like before.
first ck the nine volt battery out at the equiptment box and make sure it is good then ck to be sure all other batterys are good. Reset all defaults to factory settings and start from scratch on resetting scedules and temps. Always be sure to have fresh batteries in unit ck every year when you change the clocks for example so you don't forget. If this does not help you could have a deeper problem due to surge but ck your antenna out at the equiptment and be sure to ck all your breakers to the pumps also. I hope some of this helps and good luck
