Can anyone tell me how to access the partition hard drive so I can reformat? I have no recovery discs and can't access this part of the menu without the disc. I've tried F8, F7, F11, but still can't access reformat the hard drive. Can anyone help please? Ive even tried my HP Vista recovery disc but no good.
Another method is that you can create a bootable USB drive and in some instances, you can find the system files you need free online. Once that is created you can boot off that bootable drive by selecting the boot options for your system. Format your drive and go from there.
The only way to format is using the CD,before formatting download the network drive from HP so the you can download other softwares after formatting
SOURCE: downgrading from vista to xp sp2
I know this problem, The HDD is a SATA disk, win XP setup cannot identify a SATA controller on it's own you need to load the driver (from a disk) so you may need to download it first. I think this is the correct link http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-51521-1&lc=en&cc=us&dlc=en&product=3369431&os=228&lang=en extract the files and burn to a CD or Floppy then run win XP setup by booting from CD you should see in the begining of win XP setup from CD it prompt you to press (I think) F2 to add RAID or SCSI Controllers, (this prompt is at the bottom of the screen) Then follow the propmts to load from the disk you made earlier. you should be able to select the controller from a list. (short list) you should then be able to continue and hopefully Win XP setup should now be able to see your HDD and give you choices about which partition (as per normal) you want to remove all partitions before installing winXP (you can then make whatever partitions you wish) Hope this helps
SOURCE: Presario C700 notebook
Still cant fix this. Help please. I have now created new restore discs on dvd this time. Selected F11 to restore and its at that point you get the error?
SOURCE: Hard Drive will not boot in Compaq Presario C700
BIOS checksum errors occurs when either the BIOS chjp is faulty or most likely the BIOS battery is nearly flat and the stored info changes and doesn't match the checksum info.
Replace the battery with a new one, leave the battery out for 1/2 hour before inserting the new battery. The BIOS will be reset to the default settings, you need to configure it again eg, datr and time etc.
SOURCE: i have a compaq presario cq40 312tu running
If you can't activate your operating system then try to install a fresh copy of the operating system and get it activate again. Consider also checking the internet connection of your computer if it have connection or not.
SOURCE: Compaq Presario m200 Laptop system recovery
buy or download a windows disk. insert it and format the partition and install a fresh copy
