Tried to use instructions from a "Which" leaflet as I need to transfer photos to my digital photo frame.
you can set aol as the default email program by pressing start / then all programs or program / then you should see program access and defaults, use the program to set your email program settings all into aol. if you wish.
SOURCE: how can i remove duplicate photos in Windows photo
you have multiple thumbnails for each photo right?.
The images you see in Windows Photo Gallery are thumbnails of the actual
photo. Sometimes the
thumbnail database gets messed up. You can force a rebuild, by deleting otherwise
renaming it.
The C:\Users\[username]\AppData folder is hidden, so you can't see it until
you change your settings to show hidden files. To show hidden files, open
Windows Explorer, click on "Organize", select "Folder & Search Options",
Select "View", check "Show hidden files and folders", OK
Close WPG, then go to
C:\Users\(youraccount)\AppData\Local\Microsoft\Win dows Photo Gallery\
Rename Pictures.pd4 to Pictures.pd4.old, and re-open WPG it will get clear...Hope you will succeed...
SOURCE: Can't connect a Claire digital photo frame drivers unavailable
need instrutions for th e claire digital picture frame can you help please
SOURCE: how do i download photos from pc to digital photo
1. Connect the digital photo frame to an available USB port on the PC. Turn on the PC and the digital photo frame. Connect one end of the USB cable to the USB port on the digital photo
frame (this end is usually smaller) and connect the other end to the USB
port on the PC itself.
2. Wait for the PC to automatically detect the USB-connected digital photo
frame.
3. Move any photo files that you want to display on the digital photo
frame. Do so by copying and pasting each file into the connected USB
device that you can view in "my computer". Many
photo frames have built-in memory for this feature.
