We have a kipor IG 2600 Sinemaster, approx 3 yrs old, lightly used. Failed to keep running, sudden cut out, now won't start. Checked oil & sump is full of petrol and signs of petrol in air filter
SOURCE: Engine cant run with air filter fitted, I have cleaned it .but the problem remains the same
This means that you are over fueling. There is more fuel going to the carberator than air. By removing the air filter you are allowing more air flow into the carberator, which is allowing the engine to run right. Natural gas and propane generator must have no more than 11 inches of water column. Gasoline engines should have no more than 3.5 psi out of the electric pump. If gasoline is gravity fed, then this means that you need to rebuild the carberator or purchase a new carberator, but try to adjust the flow valve on the bowl of carberator first.
http://office.manualsonline.com/manuals/mfg/hewlettpackard_1/hewlettpackard_1_printer_product_list.html
hope it helps
