This has happened to other people in the gym on other lifestyle 95T's. and was one person was thrown off the treadmill, and injured. also, speed decrease " buttons" did not work to slow down treadmill once it increased speed. i.e. from 2.5 to 6 mph instantly, like it had a mind of its own. finally, the stop button worked. is it software? or touch screen issues ? or both?
SOURCE: I have a horizon fitness
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
SOURCE: treadmill Stex 8020 when switched on immediately
If it reaches 250km then I suspect that the upper electronics is not functioning properly contact the distributor of Stex and If under warranty they sould cover it,but send out a servicer
SOURCE: The Nordic Track machine's controls seem to be
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
SOURCE: My treadmill will start and you can increase speed
I'm not sure if this will help.
First I was unable to identiy your model. Star Trac makes 'S Series' treadmills and Pro Tread DC (5500 Pro S model) treadmills. Can you be more specific on your model?
Second. I have used Star Trac customer service in the past and they are the best. They are responsive, and knowledgeable, and will provide troubleshooting flowcharts to help you solve your problem. I highly recommend giving them a call.
Hope this helps,
Kurt
SOURCE: the speed arrow. when I
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1
Stand on the side rails of the treadmill for safety purposes. Remove the safety key.
Step 2 Press and hold the two
incline buttons. The incline buttons are blue and on the left side of
the display. Hold the up and down button simultaneously. Release the
buttons when the display reads "Calibration."
Step 3 Press the green start
button located either above or below the large, red stop button
(depending on your model). Stay on the side rails as the treadmill belt
begins to move. Both the speed and incline should go through their full
range from lowest to highest, and then back down again.
Step 4 Repeat the process if the
display does not read "Calibration Successful.
