A broken engine or tranny mount should not cause a front wheel to wobble. If this is happening with a grinding noise I'd expect more of a failing bearing or such. The grinding noise may also be a rotor of the brakes with poor pads. Yes, if a axel, or CV joint, is failing this can make noise too, often times a "clicking" type of noise. Best get the front of the van up on jack stands, remove the tires and inspect all of the front-end components; pay special attention CV joints, rotors and front axel area, loose movement in the axels?
I hope this may have helped,
Tom
Sounds like outer carrier axel bearing problem. Safety hazard exist. It could lockdown and damage your brake components. Investigate soon. Change both CV axels when you replace the bearings. You will be money and time ahead.
jack up and block up rear end for saftey pull tires off,pull 2 bolts off calaber slide calaber off,take a Cclamp to depress cylinder put new brakes in. then put the calaber back on and then tighten your bolts and then put your tires back on ext.
It sounds like it is a front end suspension problem. The following should be checked: upper and lower ball joints, the sway bars links, and even the shocks. Replace what is problematic, and your front-end noise should disappear, if it is a front suspension problem. Hopefully, this will FixYa problem!
My first reponse would be to remove ***********-in-law from the rear seat. LOL
Try applying the brakes lightly, does the squealing stop? If so it could simply be worn brake pads on that side however, this will usually happen a slow speeds as well. Another possibility could be your CV joint. Crawl under the vehicle on that side and check for a torn CV boot (rubber boot around the axel shaft where it comes out of the transmission/ or rear end and attaches to the spindle (wheel).
