It is showing 86 degrees and jets still circualte, but cannot reset the temperature as the message stays at SLP mode
SOURCE: cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
SOURCE: vcr recording speeds
Yes. SP is "Standard Play" and LP is "Long Play", while EP/SLP are short for Extended Play/Super Long Play respectively.
SOURCE: G35, 2004 SLP and vdc dash lights come on.
Haven't seen this very much on 2004's but on 03's There was a service bulletin issued on this. The bulletin directed the technician to perform an inspection of the Brake Control System. Most of the cars I ever saw with this issue had to have the VDC/TCS/ABS control unit/module replaced. The part number for the 03 model sedans is 47851-AM401. if your car is an 04 sedan the part number should begin with the same numbers. Usually there was an internal malfunction in the control unit that caused the computer module that controls and monitors this system to detect a Yaw Rate sensor malfunction which in turn caused the lights to come on and stay on. If your vehicle is a coupe, then the part numbers are a little bit different. I would recommend contacting any Infiniti dealer with your VIN number in hand and ask them if the VDC/TCS/ABS control unit has ever been replaced. Just so you know each and every time an Infiniti has been to the dealer and a repair order was written there is a record of that visit in Infiniti's database, and any dealer can access that information simply by putting in the vin number into their service computer. They can tell you where the car was originally purchased, service history, warranty repair history, any recalls, etc. I would highly suggest doing this, most dealers will even print you a copy of the complete history of the vehicle for a nominal charge. Hope this helps
SOURCE: Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
SOURCE: panel reads HHO-----, no temperature display until
"OH" is an overheat error. In normal function, it is used as a safety shut off if the spa water temperature reaches over 110 degrees in the event of a thermostat failure. But more commonly, (if the water temp hasn't gotten too hot) it indicates that the temp sensor(s) have failed. If you have a digital display on the topside controller of your spa, then it is a circuit board controlled spa pack. Most spa builders use the same control pack manufacturer - Balboa Watergroup. The sensor kit usually consists of 2 probes and wires that plug directly onto the circuit board. Depending on the spa, they could both be located onto the heater manifold, or one on the manifold and one mounted to the tub making direct contact with the water via a thru-wall sensor mount. If I knew the spa manufacturer, I could further assist you. If you replace the sensors, and encounter the same problem... then the circuit board is bad, and usually a costly replacement. The sensors are usually listed as a "BA sensor assy" Hope this helps you,
