WHEN I POWER ON ITS HANG ON, SOFT RESET BUTTON DID NOT WORK. PLEASE ADVICE
Dear mate try to reset your phone hard i.e"Hard Reset",
Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default,
Release the TALK and END buttons, and then press ENTER on your device.
SOURCE: Please help, I can't turn on my HTC. What happened?
If you have a charged battery insert it and power the phone. If it hangs or whatever then (with the phone powered on, regardless of what's been displayed) keep on the keypad the two dashes ( - ) pressed and do a reset with the stylus. Do not leave the two buttons untill a black screen appears and ask you to press send (the green call button). Press it and you are done. If your phone doesn't have a hardware damage it should start. It will start from scratch again so you might be a bit patience.
SOURCE: HTC Touch screen not responding!
This is a common problem with many touch screen phones. There are about three reasons this can happen that I know of:
1. Hardware issue. Needs to go in for repair. Hopefully under warranty still.
2. Needs to be re-flashed with the OEM ROM. This is not likely, since you've already Hard Reset, but worth a try.
3. The EASIEST and FIRST thing to check is to run a 'business card' around the edge of the screen between the case and screen. Dirt or other objects can easily get wedged into that area and hold the screen pressed down. This would prevent a press from any other area of the screen. Also, a screen protector that has shifted might cause this. Hopefully this is it, as it's a simple fix!
SOURCE: htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
SOURCE: stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
SOURCE: pulling htc s620 battery soft reset
You can do this:
- remove the battery
- press at the same time the soft keys (the 2 keys just under the screen with the symbol "-"), and do not release
- replace the battery
- always press the soft keys, press the power button (5 seconds)
- release power button
- release the soft keys
- s620 will not start windows, but open a black window
- press the send key (green telephone) to restore factory default configuration.
- s620 will enter in windows and work normally.
good luck
