The Open/Control button of the CD player and inside connection to the button is broken, and consequently I cannot use the machine.
(The remote does not have an open/control button on it - could I purchase a remote that would do the trick?.)
I love the player and would like to have it repaired.
I do not have the skills to do it myself.
Is it repairable? By whom? Would it be very time consuming and expensive?
I live in Melbourne, Australia
Thank you
Faye
Hello Fayeshep,
They are indeed beautiful machines...!!
I looked for service and customer contact
See the top & bottom of the ROTEC AU page (below)
Good luck & happy hunting...
Rotel Australia Home Theater Hi Fi and Custom Installation
SOURCE: Akai DVD recorder tray will not open
when you push the open buttom its try to open? or do nothing, any way remove the cover, and give a little push to the tray, when press the open button, listen to motor noisese, are tere? if yes, have a broke driver part, if nothing happen then you need a tech, have a damage driver circuit...good luck
SOURCE: broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
SOURCE: REMOTE CONTROL
If the product does not work because the remote is obviously faulty the dvd player is a piece of sh......t! what are you going to do about it trutech? no universl remote that I have found works..
SOURCE: panasonic dmr-e50 remote control
try unplug unit at source replug and hold in buttons play and stop at the same time for a few seconds unplug and replug again
