Question about Toshiba Satellite C655-S5068 Notebook
Will my sanyo hdtv hook up to my toshiba satellite c655
  • Toshiba Master
  • 32,281 Answers
If your TV has a VGA computer input connector, the you can connect a VGA cable from the TV to the video port on the Toshiba laptop.
Posted on Jan 27, 2013
SOURCE:
Davethesnake
  • 689 Answers
SOURCE: I have a toshiba satellite
click hide again or left click
Posted on Sep 05, 2010
Davethesnake
  • 689 Answers
SOURCE: I lost my speaker icon
try a re-boot(ctlr/alt/del) if this doesnt work re-install os--good luck!
Davey Snake!
Posted on Oct 23, 2010
  • 8909 Answers
SOURCE: cleaning my fan on my toshiba satellite c655 i
There may be information on this site that will help you;
www.insidemylaptop.com
They specialise in photographing dissasembly of laptops and most Toshiba laptops are put together the same way, so I hope it helps you.
Posted on Feb 04, 2011
haydz28
  • 115 Answers
SOURCE: the sound on my toshiba
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If same thing happened, uninstall and reinstall the audio driver. Go to start/type device manager in search box/click sound video and game controller/uninstall the audio driver and restart the laptop to take effect. Once the laptop booted up wait for the message that the device driver is successfully installed or check if the audio driver is back in the device manager. Then test the sound.
Posted on Mar 17, 2011
chadtonline
  • 93 Answers
SOURCE: have a toshiba satellite C655 yellow light is on
Your wifi is on.
Posted on Apr 07, 2011
Toshiba Laptop Satellite C655 will not power up
Take out the battery and only hook up the AC Adapter into a normal working outlet. Push the power button and if it turns on then you know the battery is bad. If you still dont get the laptop to turn on then either you have a bad AC Adapter or the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Toshiba Satellite C655-s5090 Notebook
What devices will my toshiba c655 hook up to.
You should be able to hook up to almost everything a desktop computer does
IE: printer ,wireless internet , mouse and keyboard ,
Jan 27, 2013 | Toshiba Satellite C655-S5212 Laptop
Toshiba Satellite C655-S5125 -
The Toshiba Satellite has a helpful program -- the Toshiba Wireless Manager -- to eliminate some of that frustration. Connecting to a wireless network using the built-in wireless usb wifi adapter on a Toshiba Satellite may require making some initial changes to the Satellite's settings. These changes can be made using the Toshiba Wireless Manager. As with all wireless networking, the settings of the laptop must match the settings of the network.
Mar 12, 2012 | Toshiba Satellite C655-S5125
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Toshiba c655 xp driver
Toshiba lists exactly 170 different C655 Satellite laptop models.
Find your exact Satellite C655 model number then check Toshiba downloads and support at:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Dec 16, 2011 | Toshiba Satellite Computers & Internet
Do toshiba satellites c655 have a built in mic?
The Toshiba Satellite C655 does not have a built in microphone, but it does have a mono microphone jack.
The following website has microphones that are compatible with the microphone jack. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007675%20600011221&IsNodeId=1&name=3.5mm
You may verify at Toshiba's C655 website. It says "No Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite/C650/C655-S5049
Compared with the L670. It says "Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite-pro/L670/L670-EZ1710
I hope this answers your question.
Sincerely, Nathan Hicks
Mar 01, 2011 | Toshiba (P000257700) Microphone
Do my laptop have a mic toshiba satellite c655
There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
Feb 16, 2011 | Toshiba (P000257700) Microphone
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite C655-S5068 Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
