When I turn my oven on to 350 degrees, the the temperature "beeper" goes off at 200 degrees!!!!! Should not beep until it reaches the
350 degrees I set at.
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
oven at mom's house. will get there over the week end to try this solution. thanks
