SanDisk Sansa c240 MP3 Player Logo
Posted on Jan 29, 2009
Max. micro sd card size compatible for Sansa C240
I have 2Gb now will it support 4 or 8?
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
821
Points
5
It depends on the version. v1 players can support up to 2GB. v2 players can support up to 8GB.
You can find out what version you have by going into Settings -> System and look at the version. If it starts with a 01 then it's a v1, if it starts with an 03 then it's a v2.
You can use a card up to 8GB if it's a v1 player by installing Rockbox on it. It's a 3rd party firmware for some mp3 players - although you should make sure to read any instructions for installing it, as well as read the manual.
-> Rockbox.org
I will stress this again: make sure you know what you are doing by reading installation instructions and the manual.
In order to install Rockbox on your player it needs to be in MSC mode (Settings -> USB -> MSC). If your player doesn't have the USB option in the Settings menu then you will need to downgrade your firmware. There's info on this in the Sandisk forums about how to do this.
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 21, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
1938
Points
8
The Rockbox (and other solutions here) have instructions on how to put the C240 into Mass Storage mode (MSC).
2answers
Which 32G micro sd card is compatible with the nobis nb09?
Whatever brand of card fits your budget will work.
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Will not accept a new sd micro card
Make sure that if your card is compatible with your device.
Thanks!!
2helpful
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
9helpful
4answers
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
2helpful
2answers
MAx SD size that works in a Z650 Digital camera
You can use 1GB SD card or 2GB SD card., more than 2GB is not compatible on your Z650., Gudluck!
SD card wont let me add anything
I don't think that the sansa e250 supports sdhc cards these cards 4gb and up are only compatible with newer electronics
61helpful
9answers
Sansa mp3 player could not detect micro sd add on card
Anything over 4GB is a Micro SDHC card, not a Micro SD card. It is a completely different type of card format on the inside, and despite the compatible size and shape, it will not work on devices labeled only as Micro SD card compatible. The Sansa e200 and up (e250, e260, ect.) are NOT COMPATIBLE WITH MICRO SDHC CARDS (Micro SD cards that exceed 2GB in capacity).
3helpful
5answers
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
