Question about HP Broadcom NetXtreme Network Adapter
How do i enable my ethernet driver on hp g6000
I have replaced the hard drive on my computer after i spilt wine into it and broke the old hard drive. Originally i had vista on this laptop but as i have no vista disk i have uploaded windows xp, now i can move around inside windows xp but i cannot connect to the web to upload any drivers, so i am trying to just enable my ethernet driver so i can go online..please help
  • kafbern Jan 30, 2009
    the lan card was built into the laptop and hp did not provide a cd when i purchased the laptop so thanks for trying but i still have the same problem
    I tried this but the laptop doesn't recognize that there is a lan card in it so thanks but i still have the same problem
  • 85 Answers
Install from the cd u hv purchased ur lan card
Posted on Jan 30, 2009
  • zam zam Jan 30, 2009
    ok go to device manager ther u will find lancard right click and update drivers it will automatically install
  • zam zam Jan 31, 2009
    thn thre is a problem in ur lan card replace ur lan card and check
SOURCE:
Hp lap top g6000 will not start up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 26, 2012 | HP Compaq Presario F500 F700 and G6000...
Ethernet driver missing on hp dc7700cmt computer. I have tried to use the drivers form the HP download site but the driver still comes up missing. I can't connect the computer to the internet to let...
Open the Device Manager (you can do a Windows search for it if you don't know how to open it).
Look in the Network Adapters section.
Remove your Ethernet device. Right-mouse-click it and make sure it's not disabled. If it's disabled, enable it and you should be fixed.
Otherwise, click it to highlight it and press "delete" to remove it. Then right-mouse-click on "Computer" (at the top) and "scan for hardware changes." Windows *should* install the correct driver.
Otherwise you'll need to go to the HP support site on another computer, save the driver to a flash drive, external hard drive, or CD or whatever, and then install that on your computer.
Jan 03, 2018 | HP-COMPAQ DC7700 CMT C2D/2.4 2GB-160GB...
When I go to shut my computer down, it just reboots.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
Mar 14, 2011 | HP Compaq Presario F500 F700 and G6000...
Keeps starting over and over again no writeing on lcd display will star after 100 time pushing the on botton. tested hd and memory ok ?
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 27, 2010 | HP Compaq Presario F500 F700 and G6000...
Hp compaque presario f700 sometimes working but most of the time always restarting and no display. what is the problem?
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
hope this helps
Oct 23, 2010 | HP Compaq Presario F500 F700 and G6000...
Im having trouble formatting my hitachi simplemini drive on too my Windows XP version 2002 home edition service pack 3 hp intel(R) atom(tm) ? what do i do its not appearing on my computer?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 08, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
My HP G6000 Laptop switches off at different times. I have run the diagnostic programme and it tells me to change hard drive???
well change the hard drive, the software (diagnostic)is detecting hdd failure backup your stuff fast and replace the hdd
Nov 16, 2009 | HP Compaq Presario F500 F700 and G6000...
Cant install the ethernet of compaq n610c
If the laptop is newer than 2001, it won't have a ROMPAQ on the hard drive. That was compaq's system BIOS that had to be installed on the hard drive.
If you go into the system BIOS, make sure that the ethernet is enabled.
If it is, then load into Windows and check the device manager to make sure it is there. If it isn't, a simple fix is to do a system restore to the date it worked.
In windows XP, it's c:\windows\system32\restore\rstrui.exe
In windows vista, it's c:\windows\system32\rstrui.exe
Aug 08, 2009 | Compaq Evo Notebook N610c
Wireless just was erased
goto your computers website and see if you can find the drivers for it ..might just need the drivers
if not make sure the wireless is enabled
Jul 15, 2009 | HP Compaq Presario F500 F700 and G6000...
HP Broadcom NetXtreme Network Adapter Logo
1,100 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
