SOURCE: threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
SOURCE: thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
SOURCE: Jamed Pfaff CD 7570:
Your machine probably has a thread lock which is a piece of thread caught in the hook. If this is the problem then here is the solution.
Grasp the hand wheel and turn it back and forth,increasing the amount of force used each time. It should break free after about 4-6 tries
sewman7
SOURCE: PFAFF 7570 User Manual
The only one I found is $40. http://www.sewingstyle.com/pfaff-7570.html You may be able to contact the site for additional information.
I think I would speak with a Pfaff dealer for information before spending this much for a manual.
