Question about KLH R5100 Receiver
Cannot setup Apple TV sound to KLH R5100 receiver via Optical Audio Cable
I having a issue setting up my Apple TV sound to my KLH R5100 receiver. I plugged both ends of the Optical Audio cable into their respective inputs, but I'm getting no sound from any of the receiver channels. I thought it would be simple but apparently I'm wrong. Please help if you can. Thanks!
    Sergeant:
  • 198 Answers
Call Apple and talk to setup technician.
Posted on Dec 17, 2017
SOURCE:
SOURCE: surrond sound
For Stereo Mode (Front L & R Speaker), you must plug RCA cables (match up red and white) from Output on DVD player to DVD Input on the back of the receiver. Then with speaker wire, run from receiver speaker output (Front Speakers) to designated speaker (make sure + and - match up to both input and output). As for hooking up surround sound, I'm currently trying to figure that one out with just using the L, R and Center. I don' t want wire running all over the place just for rears. Hope this helps
Posted on Sep 06, 2007
SOURCE: connect R5100 to DVR/Monitor
use component audio to the HDTV and optical audio to your KLH reciever. The component and optical are always active at the same time. I work for TWC if you have more questions.
Posted on Aug 08, 2008
  • 68 Answers
SOURCE: I just got a klh
How do you switch from one to the other?Do you have both Land R in the correct "aud in " slots,from each component.?
Posted on Sep 24, 2010
gopakumarg43
  • 76036 Answers
SOURCE: STATUS OF MY ORDER?KLH R5100 AUDIO VIDEO RECEIVER?
Sorry. I haven't the user manual for KLH 5100 audio video receiver with me now.
Posted on Nov 01, 2011
6ylucy
  • 742 Answers
SOURCE: I NEED AN OWNERS MANUAL FOR KLH R5100 AUDIO VIDEO
here is the user manual for KLH R5100
Posted on Jan 02, 2012
Nov 01, 2011 | KLH R5100 Receiver
I DON'T KNOW ALL FEATURES AND CONNECTIONS FOR MY KLH R5100 AUDIO VIDEO RECEIVER.I NEED A MANUAL FOR MY RECEIVER.
I don't have the manual with me. I found KLH R 5100 with user manual in the following link. Tray to contact them.
OK
http://www.ebay.com/itm/KLH-R-5100-Receiver-Hi-Power-/250902259353
How do I hook it up to a cable box?
The KLH R5100 only supports standard definition.
You would connect either composite (yellow) or S-video to the "Sat" connection on the rear of the receiver. For audio you would connect a stereo (red/white) analog connection to the same "Sat" connection.
Mar 01, 2011 | KLH R5100 Receiver
Turn on the R5100. Set it to any option, like
You might need to get a new receiver, seems like yours is fried
Jul 21, 2010 | KLH R5100 Receiver
Klh audio video R5100 surround sound receiver
could be 2 things....
1) The receiver could be set to feed the right speaker with more volume. Check the volume setting for each individual speaker on the receiver.
2) The cable connecting the left input from your dvd player is not connected properly or is bad. Try swapping the left and right audio input cables to see if this moves the problem to the other side. If it does - get a new cable.
May 12, 2009 | KLH R5100 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Connect R5100 to DVR/Monitor
Apr 15, 2008 | KLH R5100 Receiver
Digital/Optical Question
It's a pain in the butt getting the system set up to use the TOSlink from your PC.
Try this:
1. Hit the DVD button.
2. Use MODE/SET to get to DVD/OPT
3. Turn DSP off.
4. Use the TEST/SETUP button to make sure your speakers all work
5. Screw with your sound card!
Oct 14, 2006 | KLH R5100 Receiver
KLH R5100 Receiver Logo
109 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
