XBOX connected using HDMI and NAD says signal is Digital Dolby but only gives me Digital Dolby or Downmix Stereo as options and neither plays all speakers. Even in Digital Dolby Mode it is only giving me left and right channels. It does not allow me to select other modes like NEO etc.
XBOX is set to put out Digital 5.1 sound.
Listening Mode only gives me Digital Dolby or Downmix as options. I am not using any zones or AV Presets
NOTE: it is not the T753 shown in the product box!!! They did not have the T775 listed.
From where is the signal coming?. If it's a PlayStation, Xbox or bluray player settings may be needed in order for it to operate in the desired way. Also the content has to support Dolby Digital like a tv show even if the receiver had DD the program also has to be in DD. A lot of new players such as Fire Tv, Apple TV or Roku now send a Dolby Digital Plus signal which only newer-ish support. It's sort of a blanket signal that covers Dolby Digital but won't read as such. It will display as Dolby Digital Plus. I can help with settings if you give details on the devices. Receiver type. Media type.
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable. dvd_howtoconnect.htm for more information and pictures on DVD player hookups.
The NAD from what I've seen of the back of it has no digital audio inputs. So unless the TV has standard audio out RCA type connectors you will struggle. If it has a scart socket you can buy a scrat to phono converter. An image will be posted with this message.
However the NAD has only Dolby Surround. It has not got a Dolby Digital decoder so it can never produce the Dolby Digital sound used on DVD/Blue Ray discs or that found on HD TV broadcasts.
As you didn't say which TV model number, I can't say anything more except if it is an HD model and has digital sound connections you really need to upgrade your Receiver to one that has the latest features.
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
Start the Xbox 360 console without a disc in the disc tray.
In the System section of the Xbox Dashboard, select Console Settings.
In the Console Settings area, select Audio.
In the Audio Settings area, configure settings for analog output or digital output:
Analog output settings:
Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
Mono: Select this setting for systems that do not support stereo output.
Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
Digital output settings:
Digital Stereo: Select this setting to use digital stereo output.
Dolby Digital 5.1: Select this setting to use Dolby Digital output.
Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
TV's only will output 5.1 from HD stations. If you have a DVD player, XBOX 360, etc connected through HDMI, then the TV will only send stereo PCM through the optical out.
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround.
Before you get started, make sure you've got the following:
A digital audio output.
A free optical digital input on your receiver.
An optical digital audio cable.
Digital Audio Output
Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output.
Free Optical Digital Input
For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver.
Ready to Hook It Up? Let's Go!
Connect the digital audio output to your Xbox.
Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver.
Turn on your Xbox with no disc in the disc drive.
In the Xbox Dashboard, select Settings.
Select Audio.
You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital.
You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes.
You will see Dolby Digital Enabled in the audio screen.
Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
