Tomtom One Europe v2 GPS Receiver Logo
Posted on Jan 29, 2009
Tom tom one
Each time I switch on my tom tom one it stays on the orange coloured screen with a tom tom picture. Tapping the screen doesn't change a thing and neither does resetting it. Is this the end of its life? Have had it for just over one year.
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Jan 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
5
Helped
4958
Points
27
Have you tryed putting a pin or needle in the little hole on the back to reset it.??
NO PICTURE SOUND OKAY VS AND VA OKAY
change the colour wheel its worn u will need a tech to do it
I have done the color convergence and the picture still seems to be a bit off and now the whole screen seems to lean down on the right side.
Is the static colour bent also? It shouldn't be.
It takes hours some times top set these things up.
Cover one colour up with a piece of card whilst setting another to the donor colour. Usually Green stays static for this purpose.
Hope that helps.
I turn the power on but only the orange screen comes on with tom tom one on the screen. Screen not changing at all
If you turn on your tom tom gps device and the only thing that comes on is the tom tom display screen, then you need to reset it first. To reset it, what you have to do is to hold down the power on/off button for about 15 seconds and that will reset your tom tom, if it does the same, then you have to reinstall the tom tom application on it.
To reinstall its software, you connect it to a computer then it will detect the device, then the latest software downloads will come up, download it on to your gps, now when you plug it into your car and turn it on, it will get passed the tom tom display screen and start up normally.
Hope this information helped.
Dec 23, 2010 • GPS
Tom tom is dimming and blanking the screen within about 30 seconds. I can touch the screen and it reappears but does it again
Tap on: the main screen. Tap on: Change Preference. Tap on: Arrow Keep tapping on the arrow till you reach Preferences 6 of 6 Page. Here you will find Battery saving preference. Tap on it. Tap on: Never dim screen. (I think you selection would be dim screen between instructions at present.). Tap done. On the next screen select : Device stays on when external power is lost. (A green tick mark should appear to verify it is selected.) Tap done.
May 09, 2010 • GPS
1helpful
How do i get my tom tom back to english
I am enclosing a few screen captures to help you find your way.
Language
Tap the Change preference icon. It is the one with the blue wrench to the left of thae orange arrow on the top picture. Once you are in change preferences, use the right arrow to explore the options. Find the icon that is shown on the next picture (the Flags). Use the Up and down arrows that will show to the right of the list of languages to select the language you want.
Jan 03, 2010 • GPS
Can not get my tom tom 130 gps to read out in ehglish
Language
I have a tom tom one the box is orange i dont know
Either the volume is low or muted. You need to scroll through the menu and check sounds. There may well be a speaker with a red cross through it in your menu which will indicate it is muted. The volume control is pound by tapping in the corner of the screen-I think its bottom right. When you switch on you tomtom it may well say the version number. Does it speak for general directions? If it does and the above does not solve anything then look for the setting which lets you choose "audible alerts" or just alerts as you should have an option of getting the spoken warning which you want.
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
50helpful
3answers
Change time on tomtom GO 520
I had the same problem until my wife quickly figured it out.Touch the main part of the screen and then touch change preferences.Hit the forward arrow several times {4 on mine}then you will see "set clock".I'm not sure if i have a 520 ,but it is a tom-tom.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
