I would suggest you verify your cabling. Are you using HDMI cables? Connect a HDMI cable from the TV HDMI 1 to the Cable DVR Box, In the TV setup ,select HDMI 1 as source. If your Cable box does not have HDMI contact the provider for a updated box. With out the Make, Model of Box, Cable? Sat? Make, Model of TV. I don't know the connections?
The same thing is happening, I have moved the cord to HDMI1 but same issue.... Help very frustrating waiting 11 mins this morning
Same thing... Element 40" led 1080 model# ELDFW402 help
I'm sure you contacted your cable provider? In my Comcast DVR Xfinity Motorola HD RGN200 my Toshiba 46SL417u takes a minute or so. It's like booting my computer. Contact your provider. perhaps a new bow may help.
Pardon, BOX may help. I have a wireless adapter in the TV, I suspect that's why the TV takes so long to connect. By the way, I have a setup in the DVR that can be adjusted with the the DVR off and the TV on you user manual will explain.r
SOURCE: DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
SOURCE: we can't get the dvr/cable box to work with the tv
Assuming you have connected the DVR/Cable box with a standard co-axial antenna cable, switch on the box and go to the tuning menu on the TV.
Tuning details are in the TV manual. If you don't have the manual, download here:
https://www.p4c.philips.com/files/1/13mt143s/13mt143s_dfu_aen.pdf
When tuning is completed go through the channels to find the cable box. (Note: TV will not tune to the box if it is not switched on when tuning)
If there is still no connection, the DVR/Cable box may need connecting with a composite video cable (red / white / yellow RCA connectors), rather than just a standard co-ax cable.
The connection is at the front of the TV. There is no red connector on this TV so you will have to use an adaptor to connect both left and right (red & white) audio into the white socket. Select AV on the remote control.
SOURCE: Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
SOURCE: Mitsubishi HD 1080 Diamond distortion
iT MAY BE YOU DID NOT READ THE ORGINAL INSTRUCTIONS.iN THE MANUAL IT SAYS ON EVERY 3 PAGES NOT TO HAVE BLACK BORDERS ON MORE THEN 15% OF THE TIME.iT DOES NOT SAY WHY BUIT i BELEIVE ITS BECAUSE OF THE UNEVEN HEATING OF THE
MIRROR,TRY TO STRETCH THE SCREEN OR THERE IS AND ADJUSTMENT TO USE SEVERAL
COLORS (BEST GRAY) TO FILL IN THE 3-4 ON A 9-16 SCREEN IF YOU HAVE NOT BEEN DOING THIS FOR YEARs ,to bad so said TRY TO CONVERGE AS BEST AS POSSABLE AT THIS POINT,IF YOUR NEXT t_v BOOK SAYS TO DO THE SAME THING AT THE sTART OF EVERY CHAPTER ,WITH A WARNING ASK SOMONE TO READ TO YOU.;
SOURCE: I was watching my tv (sanyo) with cable hooked to
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
