Keys are working fine ...but their led indicators like for num, caps, wifi etc not working
Hi, If you are using a keyboard that is wireless im sure you just have to change the battery on the keyboard.
However if the keyboard is connected
to your CPU, then depending on your keyboard model, you may have to
turn F LOCK (F Lock Light on) to access system key commands if they are labeled on the front of the keys, such as num lock , scroll lock and print screen.When you click on the Flock, the lights are either supoosed to click on or off.
view the keyboard status lights by using the On Screen Display (OSD) option, Ensure you download the software ,
from your start menu do a search for your keyboard, on th key tabs setting,
its important to make sure that the correct model number is entered,
double click on the light you wish to change, in the Reassign a Key wizard,
clear the Displays (key name) status on the screen check box to disable the on-screen display, or select it so that a check mark is in the box to enable it, and then click Finish.
HOPE THIS HELPS.
SOURCE: startup problem
that wouldn't mean the processor is off, it means there is a problem with the motherboard. I don't know the exact problem with the motherboard. but it could be something wrong with the processor too. but I suggest you take your PC to like Circuit city, best buy, or your local computer shop to have them take a look at.
SOURCE: Dell D600 Lock Indicators and Volume Buttons not working
you need the dell's keyboard shortcut utility, dells hotkey and dells latest bios.
SOURCE: Laptop fails to boot up. Caps lock & Num lock
The problem may be your display LCD is not working - check that hard disk is running - when you touch you may feel a running sensation -
There are many problems It can be motherboard problem or any of the devices is not working ie.. hard disk PCMCIA Cards i suggest you should an expertize check.................
SOURCE: cannot power on only led light
Welcome to fixya, This could be a number of issues.
It could be your ram chips need to be replaced, it could be your battery.
Try this to narrow it down.
Remove the power cord, and the battery.
Press and hold the power button for 30 seconds solid.
Then, do not put the battery back in, just the power cord.
Try to start the computer, if it starts, your battery is failing.
If it does not start, leave the battery out, remove the power cord.
Turn the laptop upside down and remove and reinsert the ram chips.
Then, plug the power cord back in and try and start it again.
If it starts, your ram chips may be failing and you should think about replacing them.
KittyTech..
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
SOURCE: HP G61 NOTEBOOK PC BIOS
It would seem that your BIOS has become corrupted somehow. First try entering your BIOS setup. I believe for HP computers when you press power tap the F10 key until it opens. There you can try to reset them in some fashion and save. Try rebooting. If that fails then remove the battery and repeatedly press the power button for about 10 seconds.. (make sure it is also unplugged, this is to discharge the power from the system) then replace the battery and try booting again. Otherwise it would seem that you might have tried to load the wrong BIOS into your laptop. Check with HP then if you are still covered or not. :/
