Vizio E550VA 55 in. LCD TV Logo
Anonymous Posted on Jan 26, 2013
My Vizio LCD TV went out. Its just a black screen. The Vizio symbol turns on and off but no picture and no sound. It sounds like its similar to most peoples issues on here. How do I know if its my mai
The TV just went black in the middle of watching it last night. No popping sound just black. It turns on but no sound or picture. I have tried unplugging it all night and holding the power button for a minute to reset it but no luck. Any help would be appreciated!
Back2life Electronics
Level 3:
  • Vizio Master 933 Answers
  • Posted on Jan 27, 2013
Vizio Master
Level 3:
Answers
933
Questions
6
Helped
274636
Points
2189
There could be a few things that would cause this. I would suspect that you have a problem with either the power supply board or the main board. Based on my experience, the main boards go before the power supplies. What is the model #
  • 4 more comments
  • Anonymous Jan 27, 2013
    the model number is E550va.
  • Anonymous Jan 28, 2013
    Do you know where a good place online to order the main board would be?
  • Back2life Electronics Jan 28, 2013
    Those main boards are hard to find, that's usually not a good sign. There are two different main boards that were used in that model. You will need to find out which one you have. You can do this by taking off the back cover and looking at the part # on the main board, or by calling Vizio and provide them the serial # to your set. They can tell you which board you have by looking at your serial #. So far I have only found one main board, and it's $148. Before you order the main board, you will need to verify that the power supply is on good working order. You can do this by getting a hold of a multimeter.
    http://www.ebay.com/itm/ws/eBayISAPI.dll...
    If you power supply checks out ok, before you buy a main board, make sure the seller has a reasonable return policy as well as some type of warranty
    awesome thank you sooooo much!
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Jan 22, 2010
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Anonymous
  • 632 Answers
  • Posted on Sep 26, 2009
SOURCE: Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Anonymous
  • Posted on Jun 23, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Anonymous
  • Posted on Feb 14, 2010
SOURCE: We have a Vizio model # GV47LFHDTV10A. When we
For the cheap guy like me who will probably do more harm than good:
Also check for the F3 Fuse on that same main input board. It is located in the upper right corner. Hard wired fuses; very small. You will see F1-F4 (F4 is empty). You can solder a replacement fuse right over it. I would recommend piggybacking the fuse with a fuse you can replace. Will need the holder and a new fuse. 6 bucks.
Doesn't solve problem, but I can go another 2 1/2 years and the wife won't blame me for screwing up the TV in the first place.
Anonymous
  • Posted on Oct 21, 2010
SOURCE: Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Black Screen on Vizio E322Ar
Due to the cost of repairing this I would just replace the TV
1helpful
Vizio 55" M550NV turns on, screen displays Vizio symbol for a few seconds then turns black but the tv stays on. What is this and how can I fix it?!
Hi Tiffany, The link below is a YouTube video showing how to fix a Vizio television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
Vizio Tv With No Picture Good Sound YouTube
I have a Vizio SV470XVT1a. When I turn the tv on I may get a normal picture for a minute or two then the screen goes black or I will have a greenish or pinkish screen. I continue to have sound. Afte
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
2answers
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
3helpful
2answers
47" vizio died
Very high failure rate on this brand. Even after repair, something else will fail. Cut your losses and buy a brand name set.
5helpful
The screen on my Vizio television went blank. The
if you was trying to wipe your tv off with glass cleaner are something that can make your tv go to a black pic
3helpful
2answers
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
2answers
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
