Panasonic AG-HMC80 3MOS AVCCAM HD Shoulder Camcorder with HD and SD Recording Logo
Rusk Jones Posted on Jan 26, 2013
How do unmute audio on camera
Somehow I have lost the audio input on my camera when I am not using an external mic system..Is there a "mute" "unmute" audio setting? don't seem to be able to find it..thanks
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 36 Answers
  • Posted on Jan 29, 2013
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
36
Questions
Helped
10258
Points
75
Yes it is in setup you must go thru and resetup your device.
How to unmute my Samson Meteor Mic?
There are 2 ways to mute or un-mute the mic:
  1. Push the button on the front of the mic
  2. On the computer, open Recording Properties and go to the Levels tab and click the speaker icon next to Microphone slider.
How do you unmute the mic on dsi
On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon. Now Adjust Your Audio And Mic Setting From There. You Can Mute, Unmute or adjust the sound volume you feel best.
I have a Macbook Air with Microsoft Word Home and Student 2008 installed on it. I use the audio recording feature on in Word to take notes in lectures, but since the internal mic was not enough to capture...
In sound system preferences when the external mic is plugged in, there is a drop down menu in the input tab that says "Use the audio port for:" make sure it says input.
2helpful
When calling,i can hear the person i called but they cant hear me
Hi..
Looks like problem is on your side. This is may due to a faulty microphone on your phone or Mic is set to be on mute.
1. Please check that nothing is clotted on Microphone. This is a small hole on bottom side of your phone.
2. Please check that other party can hear you when you're using a Hands-free / Bluetooth ear phones with mic on it. If they can hear you, when you use a hands-free, problem is with your phone's on-board microphone.
3. You can also check that, while on a call, your mic is not set on Mute. This can be done as on call, select Options , look for Mute / Unmute. If Unmute is present, select it unmute the mic.
4. You can use Mute button Provided on the top side of the phone. While on the call, press this button to Mute / Unmute the mic. If the mic is set to Mute mode, other party won't hear any sound from you.
Hope this will solve the issue.
How do I switch off the audio on the Panasonic NV-GS250 so I can record video footage with no sound.
I think this camera has manual audio control.
Use the menu system and set the audio to manual then turn down the audio completely.
Another option is to place a microphone jack into the external mic socket without a mic attached. This will mute the onboard mic.
Al
My microphone wont work
It is the settings that matter. Go to the Volume icon in the system tray in right bottom corner and you will find MIC in the box that opens. Please unmute the mic and also reduce the volume for the mic. It is high volume here that is producing the screech and muted mic that does not send your speech. So do the needful here. Somehow Windows is in a habit of muting the mic on its own. Keep checking it once in a while.
Visual but no audio
Click open the volume icon in the system tray in the right bottom corner of the screen. There you will find an icon for mic. It must be muted now. Just click on its box to unmute it. And you will be heard through the mic.
2answers
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
T60: use ''mic'' minijack as ''line'' minijack
From the "ThinkPad Online User's Guide" that came with my 600E: "Note: To use the input jack for an external stereo line-in device, you need to disable the microphone function with the software on your operating system. For example in Windows 98, you can disable the function by putting a check mark in the check box of Mute for MIC in the "Master Out" window. To use the jack for a manual microphone, disable the line-in function with the software."
Microphone always muted
Make sure you don't have a program that auto mutes your mic. Possibilities are audio mixers, live messenger, etc.
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
