Computers & Internet Logo
A
Anonymous Posted on Jan 25, 2013
Usb modem lights up but mac doesn't recognize
After downloading software it still reads that "no device detected"
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 19, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
84
Points
0
I had the same problem I have a ZTE USB modem & when I connect it with mac it never show up...so I googled ZTE for Mac & I found a driver update & update for connection manager . After installing them the modem work as charm
1 Related Answer
Borhan
  • 109 Answers
  • Posted on Sep 26, 2009
SOURCE: Computer doesn't recognize device
remove previous all drivers for this device and install again, if not works , setup your OS freshly.
1helpful
2answers
I cannot download from Kodak EasyShare because it doesn't recognize my pictures, any ideas?
use a usb cable or a card reader both are mac compatible, may be a dongle will also help, go online and down load the software for mac, restart before another attempt, you may also restart the computer with you camera on and connected to to the computer by usb
1helpful
Sigma 4in1 card reader not working
Try a different / all other USB ports on the computer, and if possible, a different computer if no USB port on your computer works with it. If it still doesn't see the drive, the drive is probably not working. If it does see the device, but is asking for drivers, provide a disk with drivers that came with the reader - or check the Sigma web site for drivers that work with you OS (Windows, Mac, etc.), download and install / extract.
If it sees the device, but doesn't see the memory card, the reader may not recognize the newer, larger capacity memory cards. SD cards are smaller than 4GB in capacity, and SDHC cards are 4GB and larger. Make sure that if you're trying to read an SDHC card that the reader SPECIFICALLY says it works with SDHC cards. Most SD readers can NOT be upgraded with firmware to be able to read SDHC cards - a new SDHC reader is required.
Jan 30, 2012 • Cameras
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
MY WD MY NOTEBOOK IS NOT DETECTING DO WE NEED SOFTWARE TO INSTALL FOR DETECTION
It does have software for it, but it doesn't require it. Try to connect it to another computer, and if it works there, see if that computer has any detection software. When you connect something to an usb port if it says "this device could work faster" do not hesitate to click that button. Try all of your usb ports. If you use a mac try connecting it to a pc.
1helpful
2answers
My modem gives a response on usb device not detected every time i insert it in a computer
Well theres one of two problems here, the device is either not working properly or your usb port/card may be shot... Either or try using other usb ports and if this issue continues then try it on another computer...
My ipod doesnt want to read in my computer as soon as i dowloaded itunes. I'm running windows operating system but I didn't seem to have problems until now. I can't access the usb driver. My...
Try restarting the iPod and connect it again. If it doesn't recognize it try it on another PC, if it still isn't detected it is the iPod. Buying a Mac wouldn't help nor hurt the situation, it would just be an expenditure.
1helpful
3answers
I have a samsung GT-S5600V ive installed the software for it 'USB cable' and 'Samsung new PC studio' and ive connected my phone to the computer through the USB cable and its not searching...
HI there,
I've personally gone through this circle...ugh.
First - Reboot your computer, and your cellphone. Turn them both completely off, and back on.
If that doesn't solve it,
Second - UNinstall everything to do with your phone. Drivers/Software/Etc. Once that's done, Reboot your computer. Now reinstall the drivers/software/etc, and when that's finished, plug your phone in, let windows find and install what it needs to.
If THAT doesn't work,
Sometimes windows installs your phone as a modem, and then as a usb disk. It may be possible that you machine recognizes the modem first and runs a process to coincide with that. FInd that process and kill it, and you should be good to go!
I'm also having a problem transferring my pictures to my Mac via the USB connector. Where do I get a card reader (is this a stupid question...)? Thx.
Not a stupid question at all.
Have you tried starting iPhoto before connecting your camera to your Mac with the USB cable?
That might help with getting the photos off of your camera.
If that doesn't work, try downloading and installing Picasa for Mac. Usually Picasa is very good at detecting and supporting many different types of cameras.
http://picasa.google.com
USB reads wireless modem, software doesn't!
mac doesn't support any data card till date so this is not working . if you want to connect it install windows using bootcamp then your problem will be solved. if something importent rate this article
1helpful
USB UNKNOWN DEVICES/NOT RECOGNIZED
usb unknown devises /not recognized
Grand Canyon Tech
Grand Canyon Tech
