SOURCE: Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
SOURCE: dont know how to change the battery in Thomas Jet engine.
Hey. I was looking for the same thing and found this answer on yahoo answers:
"loosen the phillips-head screw on the underside front center of the jet engine train (you might not have noticed it - it is behind the coupling magnet assembly, which you can move to the side and also has an opening to access the screw) - once the screw is loosened, you can lift up the 'jet engine' from the base to access the battery enclosure"
http://answers.yahoo.com/question/index?qid=20071225073953AAHYJKb
SOURCE: I have a Thomas the train battery operated engine
just take the regular screw out.. then pull the blue part (the top) from the black part (plus wheels). It'll come apart.. also: the front (where the screw is) comes apart FIRST.. because the back part is kinda into the back of the train. Try it.. it's easier than you think.
