I removed the lense and tried to pressed the shutter and nothing happened
This indicates that your SD card is full and should be replaced with an empty card. If the new card has never been used before, be sure to format it. If you don't have another card, download the pictures from the full card then erase or format the card and you can then reinstall it in the camera. The numbers on the lower left side of the control panel show the number of shots remaining on the SD card.
SOURCE: D80 lcd flashing "F- -"
ive had this problem before, on my camera it means that the lens isnt rotated all the way onto its engaging point on the lens mount... it gets a little loose and shifts out of the way sometimes...
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Nikon D80 black spot center of photos
For D80, go to setup menu, select Mirror lock-up so we can see and access the sensor!
SOURCE: nikon d80 problem (err flashing with r09 in the lcd display)
yupz.... r 09,, it was not an error. it mean a value of the camera memory buffer . a memory buffer is temporary memory before your captured images stored to memory card.
The 'Err' error message, mean your camera is malfunction. and all you have to do is contact nikon service center
