I bought a Toshiba Regza 42HL67 in 2007. It is still on factory setting which is eastern time. I need to change it to mountain time. I have been trying for years. I also bought a Toshiba 32" 2 years ago. I set that one on mountain time. I tried the same process for the Regza, ... but the setup is different and the needed feature is not visably available. Can you help me change the time on the 42" Regza TV ??
SOURCE: reset tv to factory setup
Most current TV units can be reset to default factory settings by being unplug from the mains fro at least a couple of hours (or overnight).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
SOURCE: how to set up freeview on toshiba regza 32 inch tv
Make sure set on air,not cable in menu setting,Get a digital antena or a rooof antena.Hook up u should get the DTV free signal.
SOURCE: LCD tv zoomed in. can't un-zoom it.
Are you connected to a cable box with its own remote control, if so, some systems have a zoom control on the cable box remote. Check to see if it is setup to "Movie" mode or similar.
