Tv is displaying message "check fan #2" Where is this fan, and is it a simple do-it-yourself fix?
I don't know which is fan #2 but if you take the back off, you will see one fan right in front of you. The other is harder to get to. It's the black box inside the silver covering with the holes (in left lower part).
My TV was acting up by having only one color showing until I let it cool down then it would work fine. I cut a hole in the plastic back cover and mounted a bigger computer fan. Just spliced it in the wires of the little fan. Fixed the problem
SOURCE: Samsung HL-S5679W Check no. 3 fan message
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
SOURCE: My Samsung HLS5688W DLP rear projection TV
1 Is Lamp Fan, one in front of the ballast board the other is right behind DMD moduel THE big Aluimmin moduel
SOURCE: Samsung hl-s4666w DLP
Look at the Large Lamp fan and if it is not rotating it is bad and needs to be replaced. If is ok then check the other two smaller fans. You do have a bad fan.
SOURCE: my tv have vertcal lines wend I just tern on but
You are probably seeing what looks like Jail Bars (Vertical Lines evenly spaced) on the screen. If so,then the DMD chip on the DMD board is bad and needs to be replaced
SOURCE: NEED TO KNW HOW TO REPLACE NO 2 FAN ON A SAMSUNG
Here is Fan part#
BP31-00024A. Search google, find it at various places.
Light engine assembly has to be removed. This involves unplugging various connectors between processing/control chassis on the left side and engine assembly on the right side. Mounting screws on the top and bottom of engine assembly. Then remove light engine assembly completely from the TV. Fan#2 is the lamp cooling fan and is located beside the lamp assembly.
It is not too complicated if you draw a picture of where all the plugs are removed from. If one plug is not put back correctly, unit will not work. Usually a tight fight sliding out the engine. Plastic cable tie-down between the 2 assemblies can be cut and discarded, this makes re-installing light engine considerably easier.
Cheat the cabinet safety switch with tape or stretch connecting wire across it to hold it in "on" position for test after reassembly.
Service cost may be $150-$200 if you don't do it yourself. We do it in most Canada cities.
easyab
