Display problem All of a sudden my plasma TV LG has turned to half screen the left half has turned black with the right half displaying the picture. Is it something to do with the Remote ( Zoom PIP etc ) or got something to do with the picture board.
Yes, the "PIP" is the display of multiple channels at one time. On your remote you need to go to the zoom pip button and press it, if nothing go to the meno then look up the "PIP" tab and go there to try to zoom out.
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG.
No display in monitor
Jan 11, 2013 Ps3 and hdmi cable
Oct 8, 2012 More results from ccm.net
May I know what portion on the screen turned to black, is it top half, bottom half, left/right side. Also please confirm if your TV's model no. is 50PQ30C, it is printed at the rear panel, manual, and receipt.
Tv turn on now,does it have a flashes of picture only a few second than dies and than have only sound left?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards are one to the left one to the right both must be replace.The 2 long LCD inverter boards job are to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 LCD inverter boards for the replacement.
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
This can be on the matrix drive board, or the display assembly itself. It is possible to also have a defect in the address decoding area that will cause this.
The procedure is to swap out the suspect boards to determine where the fault is, leave the working boards in the set, and then follow up any necessary calibrations that are necessary.
