Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
untuk mngatasi error 210 ini biasanya gir lensa patah,solusi terbaik yaiitu ganti lngsung gir yg patah dengan yang baru. PERHATIAN ; dlam memasang gir lensa harus bener2 presisi atau pas dalam artian tidak ada yg longgar. setelah gir terpasang dngn benar lngsng nyalakan mesin dan lakukan error kode *4*error*...jika masih error 210 brarti ada kelainan di mtor lensa tersebut. thanks ARIF FAJARRIANTO_PANGKALAN BUN.
2 minggu yang lalu saya beli kamera digital kodak c142, tapi saat mau dipakai tidak bisa konek(terbuka)/digunakan, lensa sudah keluar tapi dimatikanpun tidak bisa, akhirnya saya lepas baterainya (lensa tetap tidak mau masuk). mohon solusi ya.
Always check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts. Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks Richard Scott Technical Support New Zealand
