I have an hdmi cable running from my pc to tv as a secondary display. I unplugged the tv to move some cables around, and when I plugged it back it none of the hdmi inputs work. I tried it with a different tv and no problems. Did I fry something on the tv? Thank you in advance for any suggestions.
SOURCE: Sylvania LC155SC8 remote TV code for Verizon Fios
buy the radio shack "6 in 1 remote. It has a "learning" mode that picked up all my needed commands from both my verizon fios remote and my new sylvania hdtv remote. works perfectly.
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
SOURCE: How do you hook up regular coax cable to the TV?
You simply need an "F" connector to "Belling-Lee" converter. about $4.00. At any Radio Shack, Antenna shop. This screw onto the end of the existing antenna connection & makes it so you can plug it into the Socket at back of set.
I have included a link that has a picture.
http://cgi.ebay.com/1-Coax-TV-Adapter-Connector-PAL-Male-to-F-Female_W0QQitemZ110386773163QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item19b3907cab#ht_683wt_1139
SOURCE: My LC320SLX Sylvania TV displays the message
You are getting that message becuase the MAC video resolution is too high for the TV handle, you need to lower your MAC video resolution to the native resolution of the TV, read your manual to find out what it is.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
